Hi All,
I have a Bspline Surface with a set of boundaries whose clockwise sense is set to "Solid". Is it possible through MDL API to get the equivalent set of boundaries on the same Bspline Surface whose clockwise sense is "Hole"?
Thanks & Regards,
kaab
It's not clear what you are asking. What is your definition of 'solid' and 'hole'?
Hi Jon,
To be more clear, I'll put my question this way. I have a BSpline Surface with 4 boundaries. If I see the Element Information for the Bspline Surface in MicroStation, under Geometry section, inside Trim Loop node, I see a field with name "Clockwise Sense" and its value is set to "Hole"
Now, if I change the value to "Solid", MicroStation changes the display of the Bspline Surface such that the parts which were earlier holes now become filled and the ones which were earlier filled, now become holes. But, I've seen that the Trim loops shown in the Element Information dialog still remain the same.
Now, I want to extract the boundaries of the holes shown for this new surface, using MDL API. Which API can I use for this purpose?
kaab said: I want to extract the boundaries of the holes shown for this new B-spline surface, using MDL API
How about the mdlBspline_api?
Thank you for the reply. mdlBspline APIs are always returning same boundaries regardless of clockwise sense value.
kaab said:mdlBspline APIs are always returning same boundaries regardless of clockwise sense value
So you've written some code? Post a snippet here. With some evidence, perhaps someone can help.
I remain uncertain about your interpretation of 'solid' and 'hole' and whether they match MicroStation's implementation of a B-spline surface. What is your purpose in creating a surface that is a 'hole'?
kaab said:if I change the value to "Solid", MicroStation changes the display of the Bspline Surface such that the parts which were earlier holes now become filled and the ones which were earlier filled, now become holes
Can you post here a DGN model that illustrates your point?
Actually, I've figured out that my problem would be solved if I could get the total outermost boundary curve of the original BSpline Surface along with the boundaries present on the Bspline Surface when the clockwise sense is set to "Solid".
I tried using mdlBSpline_extractBoundary function on the BSpline Surface after intentionally setting the values of numbounds and boundaries to 0. But, I got 3 separate BSpline Surfaces in the new element descriptor created by the API instead of bounding curves of the surface. Many a time, I've seen that extract boundary API fails to give correct boundary for the BSpline Surface. So, is there any alternate API to extract the whole boundary of the BSpline Surface?
Here, I'm posting screenshots of the Bspline Surface with boundaries set to solid and hole clockwise sense:
Bspline Surface with boundaries set to Solid clockwise sense
Same Bspline Surface with boundaries set to Hole clockwise sense
I'm also attaching the DGN file.
Good screenshots!
PMFJI. First of all, I need to say I am not a Bspline expert. So my advice is just for your reference.
I guess you construct your element by trimming a sphere. As a sphere, it is a closed surface, so it has no boundary. That is why you only extract 3 boundaries with mdlBspline_extractBoundary function.
Then why ElementInfo show us 4 trim loops ? I analyzed your element with the below snippet and found there are two trim loops to contruct the bottom circle (I moved one of semi-circle slightly to show them clearly).
MSElement el; MSElementDescrP edP = NULL; MSBsplineSurface bsSurface; if(SUCCESS != mdlAssoc_getElementDescr(&edP, NULL, 195, ACTIVEMODEL, FALSE)) return -1; mdlBspline_convertToSurface(&bsSurface, edP); mdlElmdscr_freeAll (&edP); edP = NULL; for (int i=0; i<bsSurface.numBounds; i++) { DPoint3d *pPoints = (DPoint3d *)dlmSystem_mdlMalloc (bsSurface.boundaries[i].numPoints * sizeof(DPoint3d)); for (int j=0; j<bsSurface.boundaries[i].numPoints; j++) { mdlBspline_evaluateSurfacePoint (&pPoints[j], NULL, NULL, NULL, bsSurface.boundaries[i].points[j].x, bsSurface.boundaries[i].points[j].y, &bsSurface); } mdlShape_create (&el, NULL, pPoints, bsSurface.boundaries[i].numPoints, -1); mdlElement_add (&el); dlmSystem_mdlFree (pPoints); } mdlBspline_freeSurface (&bsSurface);
Yongan
Back to your post topic. If you want to create a hole clockwise sense bspline surface from a solid clockwise sense bspline surface, it is really simple. Just need to change the holeOrigin and recreate the surface again. Following is the code:
MSElementDescrP edP = NULL; MSBsplineSurface bsSurface; if(SUCCESS != mdlAssoc_getElementDescr(&edP, NULL, 195, ACTIVEMODEL, FALSE)) return -1; mdlBspline_convertToSurface(&bsSurface, edP); mdlElmdscr_freeAll (&edP); edP = NULL; bsSurface.holeOrigin = !bsSurface.holeOrigin; mdlBspline_createSurface (&edP, NULL, &bsSurface); mdlElmdscr_add (edP); mdlElmdscr_freeAll (&edP); mdlBspline_freeSurface (&bsSurface);HTH, Yongan
