Convert Display Style graphic to DGN Element (Mesh)
Hi all
I would like to know if it's possible to convert a Display Style graphic to DGN Element.
For example, I have a couple of points which I convert to a Mesh element. My default Display Style for View 1 is Wireframe. I change this to Thematic:Height, which gives me a lovely picture generated based on colors and height (Z) values.
I would like to "Save" that display as an element, and use it elsewhere, i.e. Geo Web Publisher, or in other applications.
I am well aware that Display Styles are based on a View, and is NOT an element. Is there a way to overcome this?
It should function similar to the Data Acquisition tool, where points are brought in, and the Surface can be converted to Graphical Elements
