Hi All,
I got a file from my customer which they are using Bentley Building product to design. I want to edit the geometry but I can't because these geometries are attached a TriForma Dependency Linkage which prevent me to edit them. I know TFREMOVE command in Bentley building product can do this but I haven't these products. So I want to remove these linkages by my program. I coded the following program but it can't do this.
MSElementDescrP edP = NULL;mdlElmdscr_read (&edP, elemAddr[i], ACTIVEMODEL, FALSE, NULL);if (SUCCESS == mdlDependency_getLinkage (NULL, 0, &edP->el, 48640, 0)){ int status2; mdlElement_memcpy (&el, &edP->el); status2 = mdlDependency_deleteLinkage (&el, 48640, 0); // returning 1 indicates success status2 = mdlElmdscr_replaceElement (&edP, &el); status2 = mdlElmdscr_rewrite (edP, NULL, elemAddr[i]);}mdlElmdscr_freeAll (&edP); I noticed that the Required app=1 in this Linkage. Does it mean I can't delete it without TriForma application loaded ?
Attached DGN is a test dgn which only includes on solid with TriForma dependency linkage.
Any help are appreicated !
Xue
It is not the best solution, but having only MicroStation you may try to break the TriFormation linkage by saving file to DWG file format and then back to DGN. This should strip off the TriForma intelligence even you don’t have TriForma installed.
I hope this helps.
Darius
If the mdlDependency_deleteLinkage doesn't work, than because no app is registered for that specific AppId. So if you like to ruin the data by killing a foreign linkage you might even register as THE app that is responsible for this type of linkage. See mdlDependency_registerCallback, and don't forget to remove, and to test if there is still another application registered for this AppId.
It might be valid to remove those stuff on a copy of the data or if theres really no need for them, but take care that noone needs to reuse them later. You might even change those elements, when registered, but than the stored informations might differ from what the element really is, so removing the linkage is the better way if you plan any changes.
HTH Michael
You might even try with mdlDependency_setIgnoreMissingCallback(TRUE) to temporary ignore that an app is required, but this change will influence any dependencies in the current session.
Answer Verified By: xue.yulian
xue.yulian said:I noticed that the Required app=1 in this Linkage. Does it mean I can't delete it without TriForma application loaded?
The intention is to retain application-specific data so that a user may not inadvertently delete those data. You can't modify an element that has Required App = 1 because the application-specific data may become out-of-sync with the geometric data. But there are other flags in a dependency, such as Delete allowed without app., which Brien describes above.
xue.yulian said: I want to edit the geometry but I can't because these geometries are attached a TriForma Dependency Linkage which prevent me to edit them. I haven't these products
That's exactly why you can't edit them. By editing a TriForma construction with plain old MicroStation, there's a good chance that you may delete some non-graphic data that provide the TriForma intelligence.
This Triforma dependency will allow you to delete the element (Delete allow w/o app: 1). Extract the geometry to create a brand new element without any Triforma defpendencies, add the new element to the file and then delete the Triforma solid, don't try to rewrite...
HTH
-B
Thanks all ! mdlDependency_setIgnoreMissingCallbacks is what I want.
Michael Stark said:You might even register as the app that is responsible for this type of linkage
Impersonating another application! Wow! With ideas like that you are a candidate for recruitment to the secret service 8-)
Jon Summers said:you are a candidate for recruitment to the secret service
You think they are interested in recruiting a former inhabitant of a socialist country ? ;-)
Hopefully the words 'ruin the data' would have shown my intention. But from technical point of view the impersonation has its advantages, as you receive any 'touched' foreign element, instead of needing to scan for all of them. This way you might keep informations, when you haven't changed the element. (same for the ignore... method)
Michael
Michael Stark said:You think they are interested in a former inhabitant of a socialist country?
That hasn't stopped Angela Merkel!
