Hi All,
I want to get SAT string for smartsolid elements. For this purpose, when browsing through the exported functions in kisolid.dll in Dependency Walker, I found a function that seems to do exactly what I need. The function is:
mdlKISolid_satDataFromElement
But, it is undocumented. Can anyone tell me what parameters does the function take?
kaab
can someone suggest parameters that this function takes ? any help document available for this API?
Please identify the version of MicroStation, or other product such as PowerDraft, that you are using: MicroStation CONNECT or MicroStation V8i.
The APIs supplied with MicroStation CONNECT are different to those supplied with MicroStation V8i. Consequently, our answers are likely to be different.
Unknown said:mdlKISolid_satDataFromElement
That function is not documented, nor is its protoype present in the MDL header files. Whatever a SAT string is, it looks like Bentley Systems want to keep that part of the API private.
Perhaps you could describe what you want to achieve? Somebody might be able to suggest another approach.
