Hello, is there a way to create a text element with font that is not currently available?
Let's say I need to create a text element which uses 'simplex' font in first version of MicroStation V8i where normally is installed only one SHX font - 'msdefault'.
I have tried all methods (I can imagine) in MDL and API as well to get a font number using name 'simplex' but always I try to find font by name I get NULL instead of FontP.
This is what I do:
MSDgnFileP dgnFile = FontManager::GetMSDgnFileP(model); FontNumMapP fontNumMap = FontManager::GetFontMap(dgnFile); UInt32 num = 0xFFFFFFFF; FontP font = fontNumMap->FindFontByName(&num, (MSWCharCP)L"simplex", FINDFONT_All);
font is NULL...
Unknown said: is there a way to create a text element with font that is not currently available?
IMHO it's not a good idea because you may face an origin/range calculation issue (I suppose that Microstation misses some font information).
Unknown said: I have tried all methods (I can imagine) in MDL and API as well to get a font number using name 'simplex' but always I try to find font by name I get NULL instead of FontP. This is what I do: MSDgnFileP dgnFile = FontManager::GetMSDgnFileP(model); FontNumMapP fontNumMap = FontManager::GetFontMap(dgnFile); UInt32 num = 0xFFFFFFFF; FontP font = fontNumMap->FindFontByName(&num, (MSWCharCP)L"simplex", FINDFONT_All); font is NULL...
I used following workaround to "install" some font in similar situation few years ago:
HTH
Regards, Vit
Hello Vit, thanks for reply...
Could you please suggest how I can fill font table element?
Thanks.
Hi DanPaul,
I used following code snippets. It's really MDL style programmming :(
status = mdlWorkDgn_openFile (&modelRef, NULL, NULL, pathA, NULL, FALSE); status = mdlTable_getUniqueTableElm (&fontTableDsc, NULL, modelRef, MS_FONT_TABLE_LEVEL); UInt lastId = 0; status = mdlTable_getHighestEntryId (&lastId, fontTableDsc); ... MSElementDescr *entryDesc = NULL; id = 0; status = mdlTable_getNextEntryId (&id, fontTableDsc, lastId); if (id == lastId) { id++; } lastId = id; int size = 23 + fontNameLength; memset (&el, 0, 2 * size); el.hdr.ehdr.level = MS_FONT_TABLE_LEVEL; el.hdr.ehdr.type = TABLE_ENTRY_ELM; el.hdr.ehdr.elementSize = size; el.hdr.ehdr.attrOffset = size; el.buf[20] = (__int16) (id & 0xFFFF); el.buf[21] = (__int16) (id >> 16); el.buf[22] = 2 * (__int16)fontNameLength; for (int index = 0; index < fontNameLength; index++) { el.buf[23 + index] = fontName[index]; } status = mdlElmdscr_new (&entryDesc, NULL, &el); status = mdlTableEntry_validateDescriptor (entryDesc); status = mdlTable_addEntryDescriptorToChain (fontTableDsc, entryDesc);
Let me know if you find better way :)
Regards Vit
Answer Verified By: DanPaul
Thanks, I will try that...
Dan
I used to use the same method (FindFontByName) and it works as long as the font is loaded in MicroStation. Here's a better way which loads the font as long as it exists in one of the folders MicroStation scans for fonts (MS_FONTPATH):
extern "C" DLLEXPORT int GetFontByName (char *fontName ){ Bentley::Ustn::Text::FontNumMap* fonts = Bentley::Ustn::Text::FontManager::GetFontMap(mdlModelRef_getActive()); UInt32 fnum = -666; Bentley::WString wFontName(fontName); FontCP font = Text::FontManager::FindSystemFont(wFontName.c_str()); if (font == NULL) return(-1); fonts->GetFontNumber(fnum, *font, TRUE); return(fnum);}
