[v8i] Fence.GetContents enumeration slowdown vs v8XM
Hi all,
I'm hoping someone might be able to suggest a simple fix to an issue I'm experiencing.
My current task is generating a dataset for viewing at 1:25,000 scale from our base mapping which is created for main viewing at 1:250 - 1:1250 when printed.
This involves a fair bit of "clash detection" for placing text at the new size / locations and spatial analysis for grouping elements with matching attribution.
During this process I've been using (very successfully under v8 XM) a lot of fence.GetContents, with fences defined from elements created in VBA, but not added to the ActiveModel. This has been working brilliantly under v8 XM, but unfortunately v8 XM won't start unless there is an "active screen" it appears, i.e. a live user - not at the Logon Screen or connected via Remote Desktop (it otherwise crashes with a DirectX initialisation error - This "build" process must run nightly on a headless machine, which unfortunately we cannot leave "logged in" with screensaver disabled.).
v8i seems happy to start without such a live session, but when running the exact  same VBA code under v8i any sections which rely on fence scanning run at 1/4 - 1/5th the speed as v8 XM - timed by wrapping kernel32 to get a Millisecs counter in VBA.
Essentially I'm asking if there any additional settings introduced in v8i to control Fences and enumeration of their contents?
Or is slowness of fence enumeration a known issue?
  • Jon, not quite sure what happened there! I can' appear to change the "screen name" in the profile settings for that account.
    Yes we are SELECT contract members, I'll try and push through our Account Manager possibly.. as according to our SELECT administrator the last "helpful" technical support we used to have left Bentley.
    I'm pushing our IT team to get SS3 available to test - I'll see if there is any difference there.
    That is correct... only site admins and our Response Center can change that (I have asked for details separately... if you would be so kind as to provide those in the thread I split off (or offline, as was also suggested), we can get this sorted very quickly).
    Way off topic, but there are many helpful folks from Bentley who provide technical support -- you see many of them here on this site. If you have specific issues that are not being addressed, please connect with me offline about them and they will be looked into.
  • Hi Phil,
    I appreciate your response and I will reply to the account issue separately (it is a relatively minor concern - I just found it a little bizarre).
    With regards to unanswered questions - I would pose this as one of them. I have provided benchmark data and a ZIP file with sample data and code to test (see my posts above) - but no response has been forthcoming.
    The issue had dropped of the radar as I'd been pulled of onto other projects. However I've now been asked to automate the production of some CAD data on a weekly basis and this issue is rather key to getting this done!
    In brief:
    oFence.DefineFromElement and oFence.GetContents combined - appear to operate at a factor of 20 times slower in v8i SS2 compared to v8XM.
    I'm unable to use v8XM for this process as it must run "headless" on a VM under Windows 7. v8XM will not start under these conditions - throwing a DirectX init error.
    I'd really appreciate a comment from a Bentley Rep, even if it is to say "fixed in SS3!" - atleast then I can badger our IT team to test and make SS3 available.
    Alex Proffitt
  • Just to update, I installed v8i SS3 which shows the same slow down in comparison to v8XM. The search continues.
  • Jon, as always... you are the man!  Your expertise and knowledge continue to benefit me.  Thanks for sharing this alternative spatial search method.  You helped me cleanup a several thousand elements lickety-split.  My deliverable thanks you!  Existing surface colored much nicer now.
    Christopher Johnson
    Technologist/Visualization Specialist
    CH2M HILL
    135 South 84th Street, Suite 400
    Milwaukee, WI 53214
    Office - 414.847.0488
    Mobile - 414.339.9079
    www.ch2mhill.com
    Solutions Without Boundaries
