[V8i C# Addin] - How to get a dock panel to size?
I am new to microstation programming and am making an addin. I get everything to work properly but I cannot size the dockpanel. I have a keyin called 'Show' that triggers the showform function below:
internal static void ShowForm(Bentley.MicroStation.AddIn addIn)
s_current = null;
s_current = new AreaWindow(addIn);
s_current.AutoSize = false;
s_current.AttachAsTopLevelForm(addIn, true);
s_current.NETDockable = false;
Bentley.Windowing.WindowManager windowManager = Bentley.Windowing.WindowManager.GetForMicroStation();
s_current.m_windowContent = windowManager.DockPanel(s_current, s_current.Name, s_current.Name, Bentley.Windowing.DockLocation.Floating, new Size(350, 0), new Size(0,250));
s_comApp = BMI.Utilities.ComApp;
Everything works properly except the dockpanel is not 350 x 250. My form is that size but the dock panel i'm putting it into stretches larger for some reason. and just leaves padding to the right.
I've tried with/without autosize, with/without dockable. Nothing seems to work on it. Any ideas?
  • I had faced the similar problem earlier. After adding docking functionality the actual size of the form changed to some random height and width. I have used Win32 API to restore the correct size of the form. With the help of Dan Paul post http://communities.bentley.com/products/microstation/microstation_programming/f/19569/p/58662/139641.aspx I came up with the following class file.
    Create a class ResizeAddinWindow.cs in your project and copy the following code. Change the namespace (Utilities) to your project namespace.
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    using System.Runtime.InteropServices;
    using Bentley.Windowing;
    using System.Windows.Forms;
    namespace Utilities
    /// <summary>
    /// Class to resize Addin window
    /// </summary>
    public class ResizeAddinWindow
    // Rectangle layout
    [StructLayout(LayoutKind.Sequential)]
    public struct RECT
    public int X;
    public int Y;
    public int Width;
    public int Height;
    // resizing window methods
    [DllImport("user32")]
    public static extern bool GetWindowRect(IntPtr hWnd, ref RECT Rect);
    public static extern bool MoveWindow(IntPtr hWnd, int X, int Y, int Width, int Height, bool Repaint);
    [DllImport("user32.dll")]
    [return: MarshalAs(UnmanagedType.Bool)]
    private static extern bool
    SetWindowPos(IntPtr hWnd, IntPtr hWndInsertAfter,
    int X, int Y, int cx, int cy, uint uFlags);
    [Flags]
    private enum SWP
    SWP_NOSIZE = 0x0001,
    SWP_NOMOVE = 0x0002,
    SWP_NOZORDER = 0x0004,
    SWP_NOREDRAW = 0x0008,
    SWP_NOACTIVATE = 0x0010,
    SWP_FRAMECHANGED = 0x0020,
    SWP_SHOWWINDOW = 0x0040,
    SWP_HIDEWINDOW = 0x0080,
    SWP_NOCOPYBITS = 0x0100,
    SWP_NOOWNERZORDER = 0x0200,
    SWP_NOSENDCHANGING = 0x0400,
    SWP_DRAWFRAME = SWP_FRAMECHANGED,
    SWP_NOREPOSITION = SWP_NOOWNERZORDER,
    SWP_DEFERERASE = 0x2000,
    SWP_ASYNCWINDOWPOS = 0x4000
    // Method to resize the actual window
    public static bool ResizeWindow(WindowContent _contentManager, int _windowWidth, int _windowHeight)
    try
    Form _frm = _contentManager.Zone.FindForm();
    if (_frm != null)
    // To set the correct height and width
    RECT _currWindowRect = new RECT();
    if (GetWindowRect(_frm.Handle, ref _currWindowRect))
    MoveWindow(_frm.Handle, _currWindowRect.X, _currWindowRect.Y, _windowWidth, _windowHeight, true);
    SetWindowPos(_frm.Handle, new IntPtr(1), 0, 0, 0, 0,
    (uint)(SWP.SWP_NOSIZE | SWP.SWP_SHOWWINDOW |
    SWP.SWP_FRAMECHANGED | SWP.SWP_NOMOVE | SWP.SWP_NOZORDER));
    catch
    return false;
    return true;
    Usage:
    s_current.m_windowContent = windowManager.DockPanel(s_current, s_current.Name, s_current.Name, Bentley.Windowing.DockLocation.Floating);
    ResizeAddinWindow.ResizeWindow(s_current.m_windowContent, 350, 250);
    Clean and Rebuild your solution.
    Let me know if this is not what you are looking for.
    Answer Verified By: zCane75
