I'm wanting to obtain area measurements just like the flood MeasureArea command in Microstation. However, I want the user to obtain these measurements through my addin rather than that tool. I want to use the exact same function that MeasureArea --> Flood uses in microstation but I'll be modifying the data obtained for my user and that's why I need the addin.
I've not yet found a C# method for addins for obtaining a measureArea --> flood measurement once the user has clicked a coordinate in the DGN file. Does a method exist?
Hi Jon!
I use v10.01.00.15.
Hi Andrew,
Andrew Kadyshev said:I use v10.01.00.15.
This is quite old version, I guess Interop API documentation was not even published as a part of SDK.
Is there any reason why the latest MicroStation Update 7 is not used? All APIs are cleaned and enhanced in every version, so sometimes the upgrade solves the problems.
With regards,
Jan
