Hi All,
I'm having some problems with a Project at work. I am trying to speed up the process for our users to Import GIS Data that has been extracted from our GIS System
The Extract file works fine when i opened it in MicroStation, attach the coordinate system and export to Google Earth, but the boss wants to do more with it.
Essentially I would like to do the following through VBA.
User select the GIS Data file
Program creates an additional Design Model for the GIS Data
Program attaches reference file, then merges into master
Coordinate System is set to be MGA94-50
GIS Model is then Referenced into the main Design Model
Below is my code... if i do these steps manually it works, however this code gives me the attached Google Earth file (I am using google Earth simply to check that the design is in the correct coordinates)
The design should be in Esperance, Western Australia.... Not off the coast off Mexico... Also the Google Earth Image is bizzare!!
Dim sFile As StringDim sImportFile As StringDim oFile As DesignFileDim oDesignFile As DesignFileDim oModel As ModelReferenceDim oRef As Attachment 'Select GIS Extract File CommonDialog.DialogTitle = "Select .DGN File" CommonDialog.Filter = "MicroStation DGN Files (*.dgn)|*.DGN" CommonDialog.ShowOpen If FileExists(CommonDialog.FileName) = False Then MsgBox "File Not Found, Please try again", vbCritical, End End If sImportFile = CommonDialog.FileName 'Create GIS Model sFile = ActiveWorkspace.ConfigurationVariableValue("_HP_DIR") & "SEED\Sheets.dgn" Set oFile = OpenDesignFileForProgram(sFile, True) For Each oModel In oFile.Models If oModel.Name = "Default" Then Set template = oFile.Models.Item("Default") End If Next For Each oModel In ActiveDesignFile.Models If oModel.Name = "GIS Data" Then If MsgBox("GIS Data already exists in Current Design File....Do you wish to replace it?", vbYesNo + vbExclamation, sMSGTitle) = vbYes Then Set oModel = ActiveDesignFile.Models("GIS Data") If ActiveModelReference.Name = "GIS Data" Then ActiveDesignFile.Models.Item("Default").Activate ActiveDesignFile.Models.Delete oModel GoTo AddModel Else ActiveDesignFile.Models.Delete oModel GoTo AddModel End If Else GoTo ExitSub End If End If NextAddModel: ActiveDesignFile.Models.Add template, "GIS Data", "GIS Extract", msdModelTypeDefault, True ActiveDesignFile.Models.Item("GIS Data").Activate oFile.Close CadInputQueue.SendKeyin "geocoordinate assign MGA94-50" Set oRef = ActiveModelReference.Attachments.AddCoincident(sImportFile, "Default", "GIS Data", "GIS Data Extract") Dim oRefLevel As Level For Each oRefLevel In oRef.Levels If oRefLevel.Name = "BASE" Then oRefLevel.IsDisplayed = False ElseIf oRefLevel.Name = "Pole" Then oRefLevel.IsDisplayed = False ElseIf oRefLevel.Name = "SPID Anno" Then oRefLevel.IsDisplayed = False End If Next CadInputQueue.SendKeyin "fit view extended" 'merge reference Dim att As Attachment For Each att In ActiveModelReference.Attachments If att.Name = "Default" Then CopyGraphicalElements ActiveModelReference, att ActiveModelReference.Attachments.Remove att End If Next 'Attach GIS data to Default model ActiveDesignFile.Models.Item("Default").Activate CadInputQueue.SendKeyin "geocoordinate assign MGA94-50" Set oRef = ActiveModelReference.Attachments.AddCoincident(ActiveDesignFile.FullName, "GIS Data", "GIS Data", "GIS Extract")' ShowMessage "Coordinate System Set...", "MGA94-50 has been set for the current model and GIS model", msdMessageCenterPriorityInfo Unload Me CadInputQueue.SendReset CommandState.StartDefaultCommand
It seems like the problem is the attach reference line, but if i add the reference manually and ensure its placement is "coincident" it will work?
Any advice would be greatly appreciated!
Perhaps it is just a synchronization problem where you are attaching reference file earlier then it has chosen correct coordinate system. You are using SendKeyin function which just adds keyin at the end of input queue, but does not wait until it is executed. Unfortunately, VBA does not have a function to send synchronized keyin, however it can use MDL to do it.
Please, try to call ALL keyins using following SendSyncKeyin routine and let us know whether it works:
Thanks Dan,
Have tried the SendSyncKeyin and unfortunately it's the same result... the coordinate system is off and the Extract file covers the entire globe!!
Further to this...
If i open the GIS File i want to import and set the Coordinates to MGA94-50 the Google Earth file is correct... so i know its in the right coordinates.
I'm not an expert but the only thing i can think of is the code to attach the reference... is there another way to do this through code?
There are different options for the attachments. Have you tried something like this? Note the AddCoincident1 which allows for several mdsAdd options which the AddCoincident does not.
Set att = ActiveModelReference.Attachments.AddCoincident1(MapRefName, "Project MAP", _
"map", "True Scale World", msdAddAttachmentFlagCoincidentWorld)
