[v8i SS2 MDL] Opening material table
In MicroStation v8i SS2, when you copy a DGN file and its related MAT file with the same name, MAT reference may still show previous copied file. When I apply Material Editor > Table > Open command and select new MAT file it fixes the problem. It works fine in MicroStation v8i SS3.
How can I open a material table in MDL as described?
I found some mdlMaterial_xxx functions but they are used dynamically open table and free them when done.
"material activate" key-in seems to be used for this purpose but it is not accepting filename parameter.
Ahmet Sedat ALIS
AEC Technology
  • > mdlMaterial_xxx functions but they are used dynamically open table and free them when done.
    mdlMaterial_loadTable seems to take the material file name as the last argument.
    Unsure what do you mean needs to be freed afterwards here... but I guess save settings might be required.
    Cheers,
    /Chris Z.
    Hi Chris
    Thank you.
    Something like this will read material table but it will free it from memory later. I think it is a memory operation.
    Can we load more than one material table?
    mdlMaterial_initialize()
    mdlMaterial_loadTable(NULL, NULL, NULL, NULL, NULL, ..., filename)
    mdlMaterial_freeTable(..)
    mdlMaterial_cleanup()
    Ahmet Sedat ALIS
    AEC Technology
    Kind regards,
    Sedat Alis
    AEC Technology Inc.
    The entire materials API relies on dynamic data structures.  Unfortunately, since this is a C API, it's up to the programmer to manage memory allocation and deallocation, and there's a lot of that going on.
    If you are writing in C++, take the time to write some classes that wrap memory management.  That is, use the Resource Acquisition is Initialisation idiom to create and destroy memory …
     class MaterialWrapper
    private:
       MaterialType* data_;
    public:
       MaterialWrapper () { /* allocate material to data_ */ }
       ~MaterialWrapper () { /* destroy data_ */ }
    Regards, Jon Summers
    LA Solutions
    private:
    public:
    [/quote]
    Hi Jon,
    Thank you.
    Ahmet Sedat ALIS
    AEC Technology
    Kind regards,
    Sedat Alis
    AEC Technology Inc.
