When the program run, it flips the {TRUE COLOR} to {Monochrome}, but when it completes is is supposed to set the Plot to 11x17, Datafields off, Linewieghts Off and the color: Monochrome, This was recorded and a few lines added from another recording attempt. I am Unable to keep the Color: truecolor off, it flips back.
Please help, I have enclosed the code as it is and fails, any suggestions?
I have a similar example here:
communities.bentley.com/.../print-vba.aspx
