We are a company that uses Microstation software to deploy our own solution “DKmètre“ that we have developed with the C and MDL languages.
Our solution is compatible with the series 1 and 2 of the Microstation 8i version. However, updating Microstation to have the series 3 causes a bug in our application.
All texts which are displayed using the mdlTreeCell_setDisplayText fontion do not appear correctly, the last characters of words are replaced by ellipsis.
You will find attached a screen capture of our application, the words that are circled in red represent the bug.
Has someone have this kind of bugs?
Thank you for your help
OK, there is your difference: ALIGN_LEFT vs. ALIGN_RIGHT for the 2nd and 3rd column, and I don't see a TREEATTR_NOELLIPSES in the combination of the attributes.
Nonetheless, I see that it is not well documented (TREEATTR_NOELLIPSES is even not in the documentation, header file only), and without even testing anything here, that the combination of those attribs might easily lead to confusion, even because you have to define one attrib for the whole tree, not for each column, where different styles might be usefull with each of them.
Unfortunately I currently don't have an app to make some tests (use mfc dialogs, which have their own cons), but I expect Jon or Chris to easily provide additional information.
Said so, I still expect this to be a change in standard behaviour, while it is even undocumented.
I tried to add the TREEATTR_NOELLIPSES attribute, but I got a compilation error "undeclared variable". So, what is the header file name which contains this attribute definition?
Also, what do you mean by "while it is even undocumented.", is it the MS V8i SQERIES 3 ?
Thank you
If you got an compiler error, than there is a good chance that this attrib was introduced in SS3. It is only in dlogbox.h and there is no documentation about a different behaviour, nor is this attribute described in the MDLProgrammerGuide or readmeSDK. As I have only the SS3 SDK installed I cannot say if it is available in previous versions, but I think it isn't.
But, even if I include the dlogbox.h file, the compilation error always occurs. I opened the dlogbox.h file in order to look for the definition of TREEATTR_NOELLIPSES attribute, but it does not exist in this file.
HELLO Chris
So, considering these new details and exchanges, do you have other suggestions for solving the problem.
HELLO Jon
So either use the SS3 sdk, or include the define
#define TREEATTR_NOELLIPSES 0x80000000 // Columns will not show ellipses when truncated
in one of your own header files, if you need to support even older versions. (must be removed when switchign to SS3 later). In my tests, I could run all apps compiled with the SS3 sdk with each V8i. This should work, as long as you do not use the newly introduced functions, and link dynamically against the Bentley dll's (in the end the compiler is always the same MicroSoft one)
Michael
Answer Verified By: cdiTech
Hello Michael
I added the definition that you gave in your last reply, and it seems that it solved the problem :).
I’d like to know how I can use the SS3 SDK, because in one hand, I will need to use some of the functions whose definition belongs to this SDK and in the other hand I find that using the SDK is cleaner.
I come to you once again for news on sdk setup
