C# - MicroStation Addin Font Style
I'm trying to use font style upon creating a text node element however,  I encounterd an error which is No overload for method 'Find' takes '2' arguments.
Code snippet: app.ActiveSettings.TextStyle.Font = app.ActiveDesignFile.Fonts.Find(MsdFontType.WindowsTrueType, "Arial");
Do you have any idea for this one on how to set font style?
Best Regards,
Aldrin
  • Fonts.Find method requires 3 arguments, Font = object.Find (Type, NamePattern [, PreviouslyFoundFont]), because C# version you use does not support optional arguments.
    Use:  app.ActiveDesignFile.Fonts.Find(MsdFontType.WindowsTrueType, "Arial", null);
    HTH
  • Hello sir Dan,
    I'll try this one later.
    Best Regards,
    Aldrin
  • Hello sir Dan,
    I tried this one but the font style of the text node I created did not changed. Below code snippet is using ActiveSettings from the source I get.
    Font savedFont = app.ActiveSettings.TextStyle.Font;
    app.ActiveSettings.TextStyle.Font = savedFont;
    Will  ActiveDesingFile do like this or is there any other way?
    Best Regards,
    Aldrin
  • I know what is your problem (thanks to subsequent post), active font must me set BEFORE you create an element.
        public static void TextAndTextNode(string unparsed)
          Application app = Utilities.ComApp;
          Point3d origin = app.Point3dFromXYZ(583850, 639765, 9000);
          Matrix3d rMatrix = app.Matrix3dIdentity();
          Font saved_font = app.ActiveSettings.TextStyle.Font;
          double saved_height = app.ActiveSettings.TextStyle.Height;
          double saved_width = app.ActiveSettings.TextStyle.Width;
          app.ActiveSettings.TextStyle.Font = app.ActiveDesignFile.Fonts.Find(MsdFontType.WindowsTrueType, "Arial", null);
          app.ActiveSettings.TextStyle.Height = 83;
          app.ActiveSettings.TextStyle.Width = 70;
          TextNodeElement oTN = app.CreateTextNodeElement1(null, ref origin, ref rMatrix);
          oTN.AddTextLine("Text Node Line 1");
          oTN.AddTextLine("Text Node Line 2");
          oTN.AddTextLine("Text Node Line 3");
          oTN.Color = 1;
          app.ActiveSettings.TextStyle.Font = saved_font;
          app.ActiveSettings.TextStyle.Height = saved_height;
          app.ActiveSettings.TextStyle.Width = saved_width;
          app.ActiveModelReference.AddElement(oTN);
    Answer Verified By: Aldrin Almia
  • Hello sir Dan,
    Thanks a lot. It works.
    Best Regards,
    Aldrin
