I encountered error in Procedure 7. Its all about the xml file. When I tried to key-in csaddins it tells Uknown key-in or commands. Can someone help me on this matter or any suggestion?
Please see link: http://communities.bentley.com/communities/other_communities/bdn_other_communities/b/bdn-blog/archive/2011/09/29/learn-microstation-addins-step-by-step-4.aspx
Thank you.
Best Regards,
Aldrin
Hi Aldrin,
Can you upload your project source files to this forum ?
YongAn
Hello sir,
Please see attachment. Attached file is revised from your posted tutorial and I'm using Visual Studio 2005.
Aldrin,
your solution is OK, I have compiled it and it also works.
Note, load and run can be done in one keyin: mdl load csaddins; csaddins createelement textandtextnode
HTH
Answer Verified By: Aldrin Almia
Hello sir Dan,
The key that I'm missing is the 2. use following key in to load it: mdl load csaddins.
