Hi Folks,
I am writing a utility to read utility versions for all my MVBA Projects. Will I need to open all in this code in order to do this?
I have highlighted where I got to so far.
' ---------------------------------------------------------------------' GetToolVersions' Lists all strVERSION values for all MVBA Utilities'' Set a reference to the Microsoft Visual Basic for Applications' Extensibility 5.3 library (in Tools | References...)' VBIDE is the code name of this library.' ---------------------------------------------------------------------Public Sub GetToolVersions() ' Check for KeyinArguments Dim args() As String Dim nArgs As Integer args = Split(application.KeyinArguments, ",") nArgs = 1 + UBound(args) - LBound(args) If (1 < nArgs) Then Dim UName As String Dim PWord As String UName = args(1) PWord = args(2) Else ' Wrong number of arguments End If ' Prepare code project definitions Dim oVBE As VBIDE.VBE Set oVBE = VBE Dim oProject As VBIDE.VBProject Dim oProjects As VBIDE.VBProjects Set oProjects = VBE.VBProjects Dim vbaAutoloads As String Dim vbaProjects() As String ' VBA requires the following as a variant and not a string Dim vbaProject As Variant ' Get an array of AutoLoad VBA Project Names With ActiveWorkspace If .IsConfigurationVariableDefined("MS_VBAAUTOLOADPROJECTS") Then vbaAutoloads = .ConfigurationVariableValue("MS_VBAAUTOLOADPROJECTS", True) End If If .IsConfigurationVariableDefined("MS_VBAREQUIREDPROJECTS") Then vbaAutoloads = vbaAutoloads & ";" & .ConfigurationVariableValue("MS_VBAREQUIREDPROJECTS", True) End If End With vbaProjects = Split(vbaAutoloads, ";") ' Check each VBA project from list of AutoLoad VBA's Dim Count As Long For Each vbaProject In vbaProjects ' Get MVBA as path and fullname Dim strName As String Dim arrNames() As String Dim intIndex As Integer Dim PrjName As String Dim strVersion As String strName = vbaProjects(Count) arrNames = Split(strName, "\") intIndex = UBound(arrNames) PrjName = arrNames(intIndex) Debug.Print "File name: " & PrjName ' Get Procedure > Module constant strVERSION Dim oProj As VBProject Set oProj = vbaProject strVersion = oProj.EE_Header.strVersion Debug.Print "Version: " & strVersion Count = 1 + Count Next vbaProjectEnd Sub
Unknown said:I have highlighted where I got to so far. ' Get Procedure > Module constant strVERSION Dim oProj As VBProject Set oProj = vbaProject strVersion = oProj.EE_Header.strVersion Debug.Print "Version: " & strVersion
And what is your issue or question if you got so far?
Is "strVersion = oProj.EE_Header.strVersion" giving the value you are looking for?
Frank
when I needed something similar, I have used following code. It uses VBA project events OnProjectLoad/OnProjectUnload to add/remove unique configuration variable with name of my project. Then it is easy to list all my loaded VBA tools.
Unknown said:I am writing a utility to read utility versions for all my MVBA Projects. Will I need to open all in this code in order to do this?
To read a file, whether it's Excel, Word, DGN or VBA, you must first open it. It looks like you want to read some data in another VBA project, in which case that project must be...
I guess your question is really "Can I read a variable in another project without starting and running that project?" The answer is 'no'. One solution might be to provide a GetVersion method in each project, that returns that project's data of interest...
' Code in OtherProjectPublic Function GetVersion () As String GetVersion = strVersionEnd Function
Now you can execute that function with this call from your information-harvesting code...
' Code in InformationHarvester projectDim otherProjectVersion As StringotherProjectVersion = [OtherProject]module1.GetVersion
That statement of course loads the other project, but it's not the other project's main entry point (by convention, Main()) so it does not fire up the entire project. However, if the other project does some stuff automatically when it's loaded (i.e. an OnProjectLoad event handler) you can't prevent that happening.
Answer Verified By: cweber
Thankyou all for the feedback.
I suspected that I would have to open each project, but was wondering whether there was another way around it.
I believe that Jon's suggestion will be the simplest to implement. It also overcomes an issue with supplying a password when required.
I had implemented something similar to what DanPaul offered once when dealing with ProjectWise. I deprecated it in the end as integration with MicroStation is nowhere near as good as it needs to be; I experienced many issues that only delving into PW API would resolve.
I ran into a couple of problems
1. Get value from string of project.module.localvariable name
http://communities.bentley.com/products/microstation/microstation_programming/f/343173/p/91533/262507.aspx#262507
2. When calling other projects
I cannot create cyclic references where some other projects refeerence this one anyway.
