[V8i-SS2 VBA] Get value from string of project.module.localvariable name
It is a Friday and I appear to have low firing neurons today. I believe the following should be simple, but I am not seeing it?
I have a function in every VBA project:
Public Function GetVersion() As String
  GetVersion = strVersion
End Function
I then created a single utility to get version numbers for all vba projects.
Lets say I have a vba project called "myproject" and via a loop, this is loaded into a local variable, such that PrjName = "myproject"
The following code line returns the concatented string:
ProjectVersion = PrjName & ".GetVersion"
Debug.Print "Version: " & ProjectVersion
However, I actually want the value from this string combination. How can I get the value?
For Example; this code directly reads the value of a variable from a vba project as required:
ProjectVersion = myproject.GetVersion
http://communities.bentley.com/products/microstation/microstation_programming/f/343173/p/91496/262350.aspx#262350
  • Hi,
    ProjectVersion = PrjName & myproject.GetVersion
    --Robert
  • Hi Robert,
    As PrjName = myproject, your suggestion would result in the value myprojectmyproject.GetVersion being entered into the variable ProjectVersion.
    What I am after is the value that a function GetVersion() returned from another project.
    As I am looping through project names, I load PrjName with each project name, one at a time. When combining the projectname from this variable value with the function name, I get the string back not the value. Not particularly surprising, it is just that I cannot grasp how to cause the concatenated string to be treated as a call to the project > function.
  • Hi,
    I have not looked into this too much.  Would you share your code with me?  If I understand how you get your project names, then perhaps I could look at how to get this value.
    Two of my quick thoughts--I think I've seen some code for a vba writing another vba...  If you have the project name, you could have your vba write a vba to get the results from each project and return that value.
    The other idea would be to use the .SendKeyIn to send a text line to Mstn ("vba run theOtherProjectName.GetVersion")--the trick is to get the value back from that...
    --Robert
  • Perhaps you can use mdlVBA_runProcedure:
    Declare Function mdlVBA_runProcedure Lib "stdmdlbltin.dll" ( ByVal pResult As String , ByVal resultLength As Long , ByVal pProjectName As String , ByVal pModuleName As String , ByVal pProcedureName As String , ByVal nArguments As Long , ByRef pArguments As Long ) As Long
  • This seems to work...
    Option Explicit
    '   MDL function declarations must be at the beginning of the VBA module
    '   that uses them
    Declare Function mdlVBA_runProcedure Lib "stdmdlbltin.dll" ( _
        ByVal pResult As String, _
        ByVal resultLength As Long, _
        ByVal pProjectName As String, _
        ByVal pModuleName As String, _
        ByVal pProcedureName As String, _
        ByVal nArguments As Long, _
        ByRef pArguments As Long) As Long
      Private Const strMODULE_NAME              As String = "modMain"
      Public Const strVERSION                   As String = "13.10.15"
    '   GetForeignVersion
    '   Get the version of another VBA project.  This works only if:
    '   1 the other project has a module 'EE_Header'
    '   2 module 'EE_Header' contains a function returning a string named 'GetVersion'
    Public Sub GetForeignVersion()
        Const Project                           As String = "EE_CommonUtilities2"
        Dim foreignVersion                      As String
        foreignVersion = GetProjectVersion(Project)
        Debug.Print "Project '" & Project & "' version: " & foreignVersion
    End Sub
    '   GetProjectVersion
    '   Wraps MDL function mdlVBA_runProcedure declared at beginning of module
    Private Function GetProjectVersion(ByVal projectName As String) As String
        Const SUCCESS                           As Long = 0
        Const BufferLength                      As Long = 32
        Dim result                              As String
        result = Space(BufferLength)
        Dim length                              As Long
        length = BufferLength
        If SUCCESS = mdlVBA_runProcedure( _
           result, length, _
           projectName, _
           "EE_Header", _
           "GetVersion", 0, 0) Then
            GetProjectVersion = result
        Else
            Dim msg                             As String
            msg = "Unable to execute EE_header.GetVersion in project '" & _
                   projectName & "'"
            ShowMessage msg, msg, msdMessageCenterPriorityError, True
        End If
    End Function
    Regards, Jon Summers
    LA Solutions
    Answer Verified By: cweber
  • Thankyou everyone for the help :)
    I did add extra code to also include other Workspace-Project VBA files. I had to load and unload them for this, but everything works great now.
