[V8i C#] ...How to create slab form?
Hi all.
My code is running in Structural Modeler V8i(SELECTserice 1).
I want to create a slab form.
but after creating slab form (fn_MakeSlabForm - function name),
an error occurred while trying to execute the StartDefaultCommand().
How can I fix this problem?
below is my class.
Thanks.
class PlaceFormSlabClass : IPrimitiveCommandEvents
        [DllImport("stdmdlbltin.dll")]
        public static extern void mdlState_clear();
        private int       m_nIndex;
        private Boolean   m_bStop;
        private Point3d[] m_ptSlab = null;
        public void Cleanup()
        public void DataPoint(ref Point3d Point, BCOM.View View)
            int nCnt;
            Point3d[] ptTemp = null;
            BCOM.Application app = Utilities.ComApp;
            if (!m_bStop)
                fn_AddPointToPoint3D(ref m_ptSlab, Point, m_nIndex + 1);
                m_nIndex++;
                nCnt = m_ptSlab.Length;
                Array.Resize<Point3d>(ref ptTemp, nCnt + 1);
                m_ptSlab.CopyTo(ptTemp, 0);
                if (m_nIndex == 1)
                    app.ShowCommand("Place Slab Form");
                    app.ShowPrompt("Enter shape vertex");
                    app.CommandState.StartDynamics();
                else if (m_nIndex > 2)
                    app.ShowPrompt("Enter shape vertex(Reset to create Form)");
        public void Dynamics(ref Point3d Point, BCOM.View View, MsdDrawingMode DrawMode)
            int         nCnt;
            if (m_nIndex == 1)
                LineElement eleLine;
                ptTemp[nCnt] = Point;
                eleLine = app.CreateLineElement1(null, ptTemp);
                eleLine.Redraw(DrawMode);
            else if (m_nIndex > 1)
                ShapeElement eleShape;
                eleShape = app.CreateShapeElement1(null, ptTemp, MsdFillMode.NotFilled);
                eleShape.Redraw(DrawMode);
        public void Keyin(string Keyin)
        public void Reset()
            PlateForm myPlateForm = null;
            try
                foreach (Form myForm in System.Windows.Forms.Application.OpenForms)
                    if ("PlateForm" == myForm.Name)
                        myPlateForm = (PlateForm)myForm;
                        break;
                app.CommandState.StopDynamics();
                m_bStop = true;
                if (m_nIndex > 2)
                    int          nType = 0;
                    double       dThickness;
                    double       dSideAngle;
                    string       strType;
                    Point3d      ptNormal = app.Point3dFromXYZ(0,0,0);
                    TFFormRecipe tfRecipe;
                    eleShape = app.CreateShapeElement1(null, ref m_ptSlab, MsdFillMode.NotFilled);
                    if (eleShape != null)
                        if (eleShape.IsPlanar)
                            ptNormal = eleShape.Normal;
                    dThickness = Convert.ToDouble(myPlateForm.txtThickness.Text);       // Slab Thickness
                    if (myPlateForm.txtRotation.Text.ToString() == "")
                        dSideAngle = 0;
                    else
                        dSideAngle = Convert.ToDouble(myPlateForm.txtRotation.Text);    // Side Angle
                    strType = myPlateForm.cmbSideAngle.Text.ToString();
                    if (string.Compare(strType, "Angle") == 0)
                        nType = (int)TFdSlabFormSideInclinationType.tfdSlabFormSideInclinationTypeAngle;
                    else if (string.Compare(strType, "Horizontal") == 0)
                        nType = (int)TFdSlabFormSideInclinationType.tfdSlabFormSideInclinationTypeHorizontal;
                    else if (string.Compare(strType, "Vertical") == 0)
                        nType = (int)TFdSlabFormSideInclinationType.tfdSlabFormSideInclinationTypeVertical;
                    // Create Slab Form
                    tfRecipe = fn_MakeSlabForm(m_ptSlab, nType, dSideAngle, ptNormal, dThickness);
                m_nIndex = 0;
                m_bStop = false;
                //app.GetCExpressionValue("mdlState_clear()");
                //app.ShowCommand("");
                app.CommandState.StartDefaultCommand();
            catch (Exception ex)
                m_nIndex = 0;
                m_bStop = false;
                mdlState_clear();
                MessageBox.Show("Error: " + ex.Message, "Reset Error", MessageBoxButtons.OK, MessageBoxIcon.Warning);
        public void Start()
            m_nIndex = 0;
            m_bStop = false;
            Array.Resize<Point3d>(ref m_ptSlab, 1);
            app.CommandState.EnableAccuSnap();
        // Create Slab Form
        private TFFormRecipe fn_MakeSlabForm(Point3d[] ptBaseArray, int nType, double dSideAngle, Point3d ptNormal, double dThickness)
            int i;
            TFFormRecipe tfFormRecipe = null;
            TFFormRecipeSlabListClass tfSlabCls = new TFFormRecipeSlabListClass();
            try
                BTF.TFApplicationList   tfAppList = new BTF.TFApplicationList();
                BTF.TFApplication       tfApp = tfAppList.TFApplication;
                int[] nInclinationType = null;        // TFdSlabFormSideInclinationType을 저장할 배열
                double[] dInclination = null;         // Side angle을 저장할 배열
                ModelReference modRef = null;
                if (ptBaseArray.Length > 2)
                    Array.Resize<int>(ref nInclinationType, ptBaseArray.Length);
                    Array.Resize<double>(ref dInclination, ptBaseArray.Length);
                    for (i = 0; i < ptBaseArray.Length; i++)
                        nInclinationType[i] = nType;
                        if (nType == 0)
                            dInclination[i] = dSideAngle;
                        else
                            dInclination[i] = 0.0;
                    if (dSideAngle >= 0)
                        tfSlabCls.Init();
                        tfSlabCls.InitFromPoints(ref ptBaseArray, ref nInclinationType, ref dInclination, ref ptNormal, dThickness, true, TFdTriformaObjectDisplayMode.tfdTriformaObjectDisplayModeFaces, null);
                    else
                        tfSlabCls.Init();
                        tfSlabCls.InitFromPoints(ref ptBaseArray, ref nInclinationType, ref dInclination, ref ptNormal, dThickness, false, TFdTriformaObjectDisplayMode.tfdTriformaObjectDisplayModeFaces, null);
                    tfSlabCls.SetColor(3);
                    tfSlabCls.SetWeight(0);
                    tfSlabCls.SetPartFamilyName("Primary Beams");
                    tfSlabCls.SetPartName("Steel");
                    tfSlabCls.Synchronize();
                    modRef = app.ActiveModelReference;
                    tfFormRecipe = tfSlabCls.AsTFFormRecipe;
                    tfApp.ModelReferenceAddFormRecipe(modRef, ref tfFormRecipe);
                else
                    MessageBox.Show("Slab Form Fail", "fn_MakeSlabForm Error", MessageBoxButtons.OK, MessageBoxIcon.Information);
                MessageBox.Show("Error: " + ex.Message, "fn_MakeSlabForm Error", MessageBoxButtons.OK, MessageBoxIcon.Warning);
            return tfFormRecipe;
        private void fn_AddPointToPoint3D(ref Point3d[] ptPoint, Point3d ptAdd, int nArrayCnt)
            int nSize;
            try
                nSize = ptPoint.Length;     // array size
                if (nArrayCnt > nSize)
                    Array.Resize<Point3d>(ref ptPoint, nArrayCnt);
                ptPoint[nArrayCnt -1] = ptAdd;
                MessageBox.Show("Error: " + ex.Message, "fn_AddPointFromPoint3D Error", MessageBoxButtons.OK, MessageBoxIcon.Warning);
