Company wide we are having macro issues. We are all using:
Windows 7
MS V8I SS2 v8.11.7.443
Microsoft Office 2010
We operate on MDT CADSTDDs but have our own modified configuration file. Their macros have been created on a Windows XP OS and an unknown version of Microsoft Office.
When we try to execute a macro, we are encountered with error messages such as:
VBA interface error: unable to run macro - project, module, or macro not found
VBA interface error: could not find project or project file
In some instances we are encountered by errors such as this:
Oddly, a co-worker's macros started working today as I post this. Has anyone else ran across this issue before? I have my suspicions that the root cause could be a compatibility issue with the macros created on an older platform and trying to run on a newer, updated VBA interface.
Any help is appreciated,
Vinny
Unknown said:VBA interface error: could not find project or project file
If you open the VBA Project Manager (MicroStation menu Utilities|Macros) do you see the projects listed? If not, you need to adjust configuration variable MS_VBASEARCHDIRECTORIES to include the correct location of your VBA project files.
Unknown said: ...trying to run on a newer, updated VBA interface
What do you mean by 'updated VBA interface'?
Go through this: communities.bentley.com/.../225690.aspx
Frank
From my understanding (which is very minimal) is that when Microsoft Office is updated, VBA updates as well?
The configuration variable sounds very promising. I will give it a try as well as look through Frank_Klein's post as well.
Thanks for the help!
I was able to get the macros going this morning. MDT uses 1 UCF file whereas we have individual UCF files. Comparing them side by side, I found that I was missing a line of code:
MS_VBA_OPEN_IN_MEMORY = all
MS_VBASEARCHDIRECTORIES = $(MDOHDIR)workspace/programs/vba/
***MS_VBASEARCHDIRECTORIES > $(MDOHDIR)workspace/programs/vba/v8i/***
MS_VBANEWPROJECTDIRECTORY = $(MDOHDIR)workspace/programs/vba/
MS_VBAAUTOLOADPROJECTS = $(mdohdir)workspace/programs/vba/mdtprjmanager.mvba
MS_VBAAUTOLOADPROJECTS > $(mdohdir)workspace/programs/vba/mdttraffic.MVBA
MS_MACRO = $(MDOHDIR)workspace/PROGRAMS/MACRO/
MS_MACRO > $(Pref)
once it was added the macros worked!
Answer Verified By: vmorasko71
I ran into this today, along with issues with toolbox sizing. I don't know what changed overnight. I know that the search directory was correct. and I can load the VBA from the VBA project manager. but I got the above error when trying to load from the command line. this one routine (angleassistant) is supposed to load on start, which it didn't and I noticed it when the command to invoke the routine errored.
