I would like to change the name of a level, but it don't work.
I use the „Text.dgn“ Example for testing.
Here is a part of the code.
I use: bentley.interop.microstationdgn
using MicroStationDGN;
private MicroStationDGN.Application msApp;
private MicroStationDGN.DesignFile msDGN;
msApp = new MicroStationDGN.Application();
// Works
String DGNLevelName = "ClipShape";
MicroStationDGN.Level dgnLevel = msApp.ActiveDesignFile.Levels.Find(DGNLevelName);
MessageBox.Show(dgnLevel.ID.ToString());
MessageBox.Show(dgnLevel.Name.ToString());
MessageBox.Show(dgnLevel.Description.ToString());
// Works (Focus in Levenmanager switch to ClipShape)
dgnLevel.IsActive = true;
// Problem part
String newName = "Clip";
dgnLevel.Name = newName;
// Works (Levelmanager reloads)
msApp.ActiveDesignFile.Levels.Rewrite();
At this - dgnLevel.Name = newName;
i alway got a „Level-ID is invalid“.
Same is if i try - dgnLevel.Description = newName;
Debugger gives me a „Level-ID is invalid“.
I have tried some other tests, like:
msApp.ActiveDesignFile.AddNewLevel("Demo_1");
or
msApp.ActiveDesignFile.DeleteLevel("Demo_1");
All works fine.
Whats wrong with my code or the „ string Name { get; set; } “
Thank you
Harry
Hi Harry,
I tested the following code and it works well.
public void ChangeLevelName() { BCOM.Application msApp = BMI.Utilities.ComApp; BCOM.Level dgnLevel = msApp.ActiveDesignFile.Levels.Find("ClipShape"); dgnLevel.Name = "Clip"; msApp.ActiveDesignFile.Levels.Rewrite(); }
So I guess if your level is in your active design file ? If your level "ClipShape" is from level library, it can't be renamed.
HTH, YongAn
And dgnLevel.IsFromLevelLibrary can determine if your dgnLevel is from a level library.
Regards, YongAn
Hi YongAn,
thanks for those fast answer.
At this moment, i do not have testet your code.
I have still another comprehension question.
Inside your Code there is: „BCOM.Application msApp = BMI.Utilities.ComApp;“
So i have: „BCOM.Application“ and: „BMI.Utilities.ComApp;“
Both are COM Components which i have to reference.
So far, so well.
I know, no i dont know, i think, i have to do:
using BMI = Bentley.MicroStation.InteropServices;
using BIM = Bentley.Interop.MicroStationDGN;
But, related to the reference, which reference i have to use for: „Bentley.MicroStation.InteropServices“?
Sometimes i read from „xft“ of which i now point that it is: „XFM Feature Toolkit“.
So, my question is, where are all those documentations from which i experience, which component i have to use and which reference i have to set? There are none API Reference or documentation about that? Most time i read: „Look inside the MicroStationVBA.chm“, all you need to know is inside that help. But it is not, as we can see.
Is the knowledge which i need all inside the „closed bentley selection AREA 51 section“?
If yes, than the only chance which i have is to go to my customer and ask him, if it is possible to make such a SELECTService account for me.
Harry, did you read YongAn's tutorials?
Please refer to: Learning MicroStation Addins Step by Step series.
http://communities.bentley.com/members/yongan.fu/blogs/default.aspx
DanPaul,
YongAn's tutorial is in the BDN Member section. I have no SELECTE subscriber level. Thats part of my question above. The good knowledge is in the closed area ;-)
Harry, if you are going to sell your programming products (I assume that because you mentioned a customer), I think you MUST be a Commercial BDN member! Select BDN is relevant only for internal company programming.
Unknown said:If yes, than the only chance which i have is to go to my customer and ask him, if it is possible to make such a SELECTService account for me.
As far as I know...
If you are going to sell your programming products, you MUST be a Commercial BDN member!
Select BDN membership is relevant only for internal company programming.
No I do not sell the development.
And no it is not really a customer, more an acquaintance.
He is a customer of many years of Bentley Microstation.
It's more like a "can you fix this problem for me".
I'm not a Microstation User, i'm a developer.
I only wanted to know, if the expert knowledge and forum is in the BDN area.
After adding a new Level you have to rewrite the level table (class/object: Levels)
from the mvba help:
Sub ToggleLevelDisplay(att As Attachment, strLevelPattern As String)Dim lvls As Levels Dim lvl As Level Set lvls = att.Levels For Each lvl In att.Levels If lvl.Name Like strLevelPattern Then lvl.IsDisplayed = Not lvl.IsDisplayed End If Next lvls.Rewrite RedrawAllViews End Sub
Remarks from the vba help for AddNewLevel Method
This method returns the newly-created Level object.
Subsequently, you should call Levels.Rewrite to make the change permanent.
Version
08.00.00
Ohhh i see, Yogan was already saying this!
Frank
My "Learning MicroStation Addins Step by Step" articles are in China BDN area which every Be Communities register can read.
Apologize for my disfluent English in these articles. But I promise my native Chinese is fluent. :-)
YongAn
