Change Model Properties in VBA
Before I jump into this, I thought I'd ask here first.
Does anyone have some VBA code that changes a model from design model to a sheet and then applies some of the additional properties that become available once a model is a sheet?
I tried recording a macro, but the result was not useful.
I am using InRoads to create plan and profile sheets. But it does not know sheets models from design models, so after its complete, I need to open evey sheet, change the model to a sheet, assign a scale, select a sheet size and tell it which reference file is my sheet.
And then, if I have to rerun the plan and profile generator, it all gets reset and I have to start all over again..
