I have a tool bar button that brings on Level 5 and sets the various colors, weight and style
Sub ActiveLayerSet5()' 110413 - Changed command, removed Dim commands and the Command CommandState.StartDefaultCommandStart command' 09/23/2013 - SetCExpressionValue "tcb->symbology.color", 5, "MGDSHOOK" {This sets the actual color a -1 uses the bylevel}' 021313 - Tested again,
' Start a command CadInputQueue.SendCommand "ACTIVE LEVEL ""Level 5""" ' Set a variable associated with a dialog box CadInputQueue.SendCommand "ACTIVE Color Violet" CadInputQueue.SendCommand "ACTIVE STYLE 0" CadInputQueue.SendCommand "ACTIVE WEIGHT 0" CadInputQueue.SendKeyin "level set lock ON Level 5" CadInputQueue.SendKeyin "m,msLevel 5 Lock = ON" CadInputQueue.SendCommand "m,ms Active Level=5 Color 5, Style 0, Weight 5" 'Send Msg Center Box End Sub
as soon as I turn on 5, my temporary level. I have to do the manual pull down and turn on the padlock to lock the layer. (I have a reason for all this) I tried to find a key-in to turn the lock on , searched in ask Inga, found several on locking other things. I want through an array of Key-in commands attempting to find mine?
If there is a Key-in I can make it work, or if a VBA command, that would be great. If I get the one I can figure out the other. I did try to copy this with the Basic Macro and it got nothing in-between
' Turn on Level 5 Lock
Sub main Dim startPoint As MbePoint Dim point As MbePoint, point2 As MbePointEnd Sub
I went through the pull-down step, went to 5 and turned on the lock symbol, but you can see none of it was recorded?
VBA Recording:
Sub Macro1() Dim startPoint As Point3d Dim point As Point3d, point2 As Point3d Dim lngTemp As Long
CommandState.StartDefaultCommandEnd Sub
Still did not pickup setting the lock, can someone help on this one?
Thank you so very much and all worked, I already updated my setlevel5, I also discovered you could turn on the Lock status in the Level manager and even turn it off and on from there, I did not realize all the extra options the Level manager offered. So great to have folks willing to help others.
RJB Phillips III - Praise the Lord for His Mercy and Grace
