Good day,
I was wondering what kind of code I would need to access MicroStation named fences.
I have created a program that counts cells in a particular active cell.
I have saved a number of named fences in my drawing, and would like to apply the same program to them, without having to manually select and activate a fence from the named fences.
What i would like to do would be something like this:
For Each mfence As Fence In ActiveModelReference.NamedFences scanFence() 'already existing functionNext
Next
the above code assumes that i can access the NamedFences as a collection, or array.
I found that the Fence object in MVBA has a ActiveDesignFile.Fence.GetFenceNames as a member, but i could only get a handle of the names,
and could not actually get the fence object itself in order to perform the scan.
What is the proper way to do this.
Thanks in advance
Am using Windows 7, 64 bit. MicroStation V8i Select Series 3
I hope it will be more clear how to work with Named Fences from VBA (not sure if it's the best approach, but it should work ;-).
Named fence is stored as hidden shape file in a model, the only available information is it's a shape defining a fence and its name. It means to use Name Fence, you have to receive the fence name, to receive defining element (closed shape), use the element to create active fence and after it you can receive element enumerator.
Sub NamedFence() ' Obtain an array of fences' names Dim fences() As String fences = ActiveDesignFile.fence.GetFenceNames ' Go through the receive array of fence names Dim highBound As Integer highBound = UBound(fences) Dim counter As Integer For counter = 0 To highBound ProcessFence (fences(counter)) NextEnd SubSub ProcessFence(fenceName As String) ' Receive element, which belongs to the named fence Dim fenceElement As Element Set fenceElement = ActiveDesignFile.fence.GetElementFromName(fenceName) ' Create the active fence from the element Dim lastView As View Set lastView = CommandState.lastView ActiveDesignFile.fence.DefineFromElement lastView, fenceElement ' Set fence mode here ActiveSettings.FenceClip = True ' Receive fence content Dim enumerator As ElementEnumerator Set enumerator = ActiveDesignFile.fence.GetContents ' Enumerate fence content and do what you need Do While enumerator.MoveNext enumerator.Current.IsHighlighted = True LoopEnd Sub
With regards,
Jan
Answer Verified By: theGreg
