Tag Extraction to Excel
Hi everyone just wondering if i can get some help on a code for extracting tag text to excel.
The code I have used is out of the Book Learning Microstation VBA by Jerry Winters
the code is listed below, the only things i have changed is the target tag to reflect my tag set and the folder location where i want it to look.
i get a Run Time Error '91' Object Variable or With Block Variable not set on the Set my folder  line
any help would be much appreciated
Sub ExportTags()
Dim myDGN As DesignFile
Dim myFSO As Scripting.FileSystemObject
Dim myFolder As Scripting.Folder
Dim myFile As Scripting.File
Dim myTagSet As TagSet
Dim myTagDef As TagDefinition
Dim TargetTagset As String
Dim myTag As TagElement
Dim myElemEnum As ElementEnumerator
Dim myFilter As New ElementScanCriteria
'New Declarations
Dim myExcel As Excel.Application
Dim myWS As Excel.Worksheet
Dim CurRow As Long
'New Code
Set myExcel = New Excel.Application
myExcel.Visible = True
myExcel.Workbooks.Add
Set myWS = myExcel.ActiveSheet
CurRow = 2
TargetTagset = "WDG-A1"
Set myFolder = myFSO.GetFolder("C:\Users\Westech\Desktop\Testing Folder")
For Each myFile In myFolder.Files
Select Case myFile.Type
Case "Bentley MicroStation Design File"
'File Name and Merge Cells
myWS.Cells(CurRow, 1) = myFile.Path
myWS.Range("A" & CurRow & ":F" & CurRow).MergeCells = True
myWS.Range("A" & CurRow, "F" & CurRow).BorderAround _
, xlThick
'Header
CurRow = CurRow + 1
myWS.Range("B" & CurRow) = "Tag Set Name"
myWS.Range("B" & CurRow).Font.Bold = True
myWS.Range("C" & CurRow) = "Tag Name"
myWS.Range("C" & CurRow).Font.Bold = True
myWS.Range("D" & CurRow) = "Tag Value"
myWS.Range("D" & CurRow).Font.Bold = True
myWS.Range("E" & CurRow) = "ID High"
myWS.Range("E" & CurRow).Font.Bold = True
myWS.Range("F" & CurRow) = "ID Low"
myWS.Range("F" & CurRow).Font.Bold = True
CurRow = CurRow + 1
'Open the File
Set myDGN = Application.OpenDesignFileForProgram( _
myFile.Path, True)
For Each myTagSet In myDGN.TagSets
Select Case UCase(myTagSet.Name)
Case UCase(TargetTagset)
myFilter.ExcludeAllTypes
myFilter.IncludeType msdElementTypeTag
Set myElemEnum = myDGN.Models(1).Scan(myFilter)
While myElemEnum.MoveNext
Set myTag = myElemEnum.Current
'Write to Excel
myWS.Cells(CurRow, 2) = TargetTagset
myWS.Cells(CurRow, 3) = myTag.TagDefinitionName
myWS.Cells(CurRow, 4) = myTag.Value
myWS.Cells(CurRow, 5) = myTag.ID.High
myWS.Cells(CurRow, 6) = myTag.ID.Low
CurRow = CurRow + 1
Wend
End Select
Next
myDGN.Close
End Select
Next
End Sub
  • Without testing  I'm missing:
    Dim myFSO As NEW Scripting.FileSystemObject
    More info: http://support.microsoft.com/kb/186118/EN-US
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • VBA References
    External applications require a VBA Reference.  Use the Tools|References menu in the VBA Interactive Development Environment (IDE) to pop the References dialog.  You'll see a long list of objects that you can choose.  The object for the Microsoft Scripting Runtime is scrrun.dll, for example.
    Regards, Jon Summers
    LA Solutions
  • MicroStation Tag Tools
    Unknown said:
    Just wondering if I can get some help on a code for extracting tag text to Excel...
    MicroStation's built-in tag reporting tools let you create a CSV text file.  Excel can open a CSV file.  No programming required! The downside is that you have to fight your way through the MicroStation documentation about tag reports.
    MicroStation menu Element|Tags|Generate Reports pops the Tag Reports dialog.  This is initially mistifying, because it wants you to identify a report template (.tmp) file.  Make a report template from menu Element|Tags|Generate Templates, which pops the Generate Templates dialog.
    With the Generate Templates dialog open...
    1. Choose your tag set
    2. Choose those tags whose values you want to appear in the report
    3. Save the template
    Once you have a report template, you can generate a tag report from the Tag Reports dialog.
    LA Solutions
  • Hi Frank thanks for your help, it has stopped the run error But all i get is excel to open but it wont export the tag data. need to have a look at this in the new year. thanks for your help
  • Thanks Jon, I know that there is the tag export function but it doesn't seem to work very well in the new AECO Sim. Still having problems with my code the "AS NEW" suggested has stopped the run error i was getting but now it only opens excel but it does not export the data form the DGN files, will have to look at this in the new year, thanks for all your help
  • FlexiTable™ Exports Tags to Excel
    Unknown said:
    Just wondering if I can get some help on a code for extracting tag text to excel
    You can accomplish your task, without any programming, using FlexiTable.
    LA Solutions: FlexiTable
    FlexiTable can harvest all kinds of data, including tag values, from a MicroStation DGN model. You can save data in several formats, including a Excel workbook, HTML, XML and CSV.
    LA Solutions
  • Hi Dabid,
    i checked your code and it almost worked. Please see my modifications below.
    I identified a weakness in your code when it examines the file type. Maybe it would be better to compute the file extension and use the result in the Select-Case-Statement.
    Merry Christmas.
    Sub ExportTags()
       'SB: Changed
       Dim myFSO As New Scripting.FileSystemObject
       'New Declarations
       'SB: Changed
       Dim myExcel As New Excel.Application
       Dim CurRow As Long
       'New Code
       'SB: Changed
       'Set myExcel = New Excel.Application
       CurRow = 2
       TargetTagset = "Sample"
       Set myFolder = myFSO.GetFolder("D:\Projekte\2013\BentleyForum_TagExport")
           'not sure if that is the best way to examine file type. What about file extensions
           Debug.Print myFile.Type
               'SB: Changed
               Case "Bentley MicroStation Design"
                                                    , xlThick
                   'Header
                   CurRow = CurRow + 1
                   CurRow = CurRow + 1
                   'Open the File
                                                   myFile.Path, True)
                                   'Write to Excel
                                   CurRow = CurRow + 1
                               Wend
                       End Select
                   Next
                   myDGN.Close
           End Select
           Next
    End Sub
  • Thanks Stefan,
    I have managed to get this working, but you are correct I need to specify the file extension as the only files that it reports the tag sets on is .hln files and doesn't do any of the .dgn files. but i cant work out how to call it out.
    Has anyone got any suggestions??
    Sub ExportTags()
      Dim CurRow As Long
      CurRow = 2
      Set myFolder = myFSO.GetFolder("C:\Users\Westech\Desktop")
      For Each myFiles In myFolder.Files
          Debug.Print myFiles.Type
          Select Case myFiles.Type
              'SB: Changed
                  myWS.Cells(CurRow, 1) = myFiles.Path
                                                   , xlThick
                  'Header
                  CurRow = CurRow + 1
                  CurRow = CurRow + 1
                  'Open the File
                                                  myFiles.Path, True)
                                  'Write to Excel
                                  CurRow = CurRow + 1
                              Wend
                      End Select
                  Next
                  myDGN.Close
          End Select
          Next
    End Sub
  • New Topic: New Thread
    Your question has little to do with this thread's title about Tags.  I suggest that you post a new question.
    You're getting all the files in C:\Users\Westech\Desktop.  Those can be any file type.  The Debug.Print statement tells you what you've found.  You could add other members of MyFiles (e.g. MyFiles.Name) to that print statement to clarify what you're getting.
    That test ensures that you're working only with those files whose type Windows believes to be Bentley MicroStation Design.  I don't see how that can result in only .hln files, unless there are no .dgn files in that folder.  If you examine that folder, what files are present?
    Microsoft File System Object
    You can find out more about the File System Object.
    LA Solutions
