Hi Folks, I am executig code to test for the version of install external to MicroStation using VBS (company is not yet commissioned for PowerShell) on Win 7 and the following test fails to find the folder?If InStr(1, subFolder, "08.11.07.443", vbTextCompare) > 0 Then
The folder in question is 'C:\Documents and Settings\All Users\Application Data\Bentley\Microstation'
The subfolders being tested recursively are '8.11' and '08.11.07.443'. The test does work if I remove the '8.11' folder!
Any ideas?
Unknown said:The subfolders being tested recursively are '8.11' and '08.11.07.443'. The test does work if I remove the '8.11' folder
What sub-folders exist in the C:\Documents and Settings\All Users\Application Data\Bentley\Microstation directory? Do both \8.11 and \8.11.07.443 exist, or just one of those? Show us more code where you search for those folders.
Hint: you might do better to post your question to a site that deals with VB script.
Bear in mind that, with differing versions of Windows and MicroStation, those folders will also differ. A more reliable approach is to query the Windows Registry to determine where MicroStation and its data files are installed.
You can query the Registry using VB Script. Here are some related links …
1. Both \8.11 and \08.11.07.443 exist
2. I have posted the same question to MSDN
3. I am testing for different OS. Unfortunately this is an addendum to existing scripts during a several month process of changing from WinXP to Win7. PowerShell is not yet approved for use. I have been reluctant to check the registry only because it is new to me and I had hoped to accomplish my requirement in the shortest timeframe.
I've just been stumped as to why the Instr has an issue with multiple folders beginning with '8' and/or with '08'. I may have to try the registry if I can't get this working...
Unknown said:I had hoped to accomplish my requirement in the shortest timeframe
Well, we all hope that. Then we bump into something big and immovable.
Unknown said:I've just been stumped as to why the Instr has an issue with multiple folders
We still can't see your code, so it's hard to comment further. How are you obtaining the list of sub-folders?
Hi cweber,
of course instr(1,subfolder,'8.11',..) returns a value greater than 0 for '08.11.07.443'.
It returns 2.
You have to check if Instr() returns 1 which is only the case if the string starts with the sub-string you test.
Read the Help for Instr to be sure about the function.
Function GetMicroStationVersion()
Const USTN_APP_VERSION_SS2 = "V8i_SS2"
Const USTN_APP_VERSION_SS3 = "V8i_SS3"
Const USTN_APP_VERSION_SS3U1 = "V8i_SS3_Update_1"
Const USTN_APP_VERSION_SS3U2 = "V8i_SS3_Update_2"
Const UKNOWN_VERSION = "UKNOWN_VERSION"
Const WinDataXP = "C:\Documents and Settings\All Users\Application Data\Bentley\MicroStation\"
Const WinProgXP = "C:\Program Files\Bentley\MicroStation\"
Const WinData7 = "C:\ProgramData\Bentley\MicroStation\"
Const WinProg7 = "C:\Program Files (x86)\Bentley\MicroStation\"
Dim PathProg
Dim PathData
Dim Osys
' Determine Operating System
If oFileSys.FolderExists(WinProg7) And oFileSys.FolderExists(WinData7) Then
Osys = "Windows 7"
PathProg = WinProg7
PathData = WinData7
ElseIf oFileSys.FolderExists(WinProgXP) AND oFileSys.FolderExists(WinDataXP) Then
Osys = "Windows XP"
PathProg = WinProgXP
PathData = WinDataXP
Else
Wscript.Echo "Error: Valid Windows OS not found!"
End If
'Wscript.Echo Osys
' Get MicroStation version from child folders
Dim GetPP
Dim GetPD
GetPP=TraverseFolders(oFileSys.GetFolder(PathProg))
Wscript.Echo GetPP
GetPD=TraverseFolders(oFileSys.GetFolder(PathData))
Wscript.Echo GetPD
If GetPP = GetPD Then
GetMicroStationVersion = GetPP
Wscript.Echo "Error: Valid installation not found!"
End Function
' Recursion - create a self-referencing function
Function TraverseFolders(folder)
TraverseFolders = vbNullString
Dim subFolder
For Each subFolder In folder.SubFolders
' Recurse on all the sub-folders
TraverseFolders subFolder
'Wscript.Echo subFolder
' Get the installation path once the recursion is done
If InStr(1, subFolder, "08.11.09.459", vbTextCompare) > 0 Then
TraverseFolders = USTN_APP_VERSION_SS3U2
ElseIf InStr(1, subFolder, "08.11.09.357", vbTextCompare) > 0 Then
TraverseFolders = USTN_APP_VERSION_SS3U1
ElseIf InStr(1, subFolder, "08.11.09.292", vbTextCompare) > 0 Then
ElseIf InStr(1, subFolder, "08.11.07.443", vbTextCompare) > 0 Then
TraverseFolders = USTN_APP_VERSION_SS2
TraverseFolders = UKNOWN_VERSION
Next
Jon, your suggestion worked here at home;
vn(0) = InStr(1, subFolder, "08", vbBinaryCompare)
vn(1) = InStr(1, subFolder, "11", vbBinaryCompare)
vn(2) = InStr(1, subFolder, "09", vbBinaryCompare)
vn(3) = InStr(1, subFolder, "459", vbBinaryCompare)
If vn(0) > 0 And vn(0) < vn(1) And vn(1) < vn(2) And vn(2) < vn(3) Then
'If InStr(1, subFolder, "08.11.09.459", vbTextCompare) > 0 Then
vn(3) = InStr(1, subFolder, "357", vbBinaryCompare)
vn(3) = InStr(1, subFolder, "292", vbBinaryCompare)
vn(2) = InStr(1, subFolder, "07", vbBinaryCompare)
vn(3) = InStr(1, subFolder, "443", vbBinaryCompare)
Unknown said: ' Determine Operating System If oFileSys.FolderExists(WinProg7) And oFileSys.FolderExists(WinData7) Then Osys = "Windows 7" PathProg = WinProg7 PathData = WinData7 ElseIf oFileSys.FolderExists(WinProgXP) AND oFileSys.FolderExists(WinDataXP) Then Osys = "Windows XP"...
Just for the purpose of information sharing, the script below is how I determine Which OS and Version a user is running, and What Bitness the OS is. This is used in our BentleyTSGReport.txt (ftp://ftp.bentley.com/pub/tools/utilities/BentleyTSGReport.txt) data collection script.
:: Identify Windows version - Ref: http://en.wikipedia.org/wiki/Ver_(command)#Version_listset OSVER=for /f "tokens=4 delims=[.]" %%d in ('ver') do ( if %%d==2195 (set OSVER=WIN2000 && set OSIDX=1 ) else if %%d==2600 (set OSVER=WINXP && set OSIDX=2 ) else if %%d==3790 (set OSVER=WINXP64-WIN2003 && set OSIDX=3 ) else if %%d==6001 (set OSVER=VISTA && set OSIDX=4 ) else if %%d==6002 (set OSVER=VISTA-WIN2008 && set OSIDX=5 ) else if %%d==7600 (set OSVER=WIN7-WIN2008R2 && set OSIDX=6 ) else if %%d==7601 (set OSVER=WIN7-WIN2008R2-SP1 && set OSIDX=7 ) else if %%d==9200 (set OSVER=WIN8-WIN2012-SP1 && set OSIDX=8 ) else if %%d==9600 (set OSVER=WIN81-WIN2012R2 && set OSIDX=9 ) else (set OSVER=UNKNOWN: %%d && set OSIDX=32768))
:: Identify Windows architecture (64 or 32 bit) set OSARCH=&&set WOW6432Node= if defined ProgramFiles(x86) (set WOW6432Node=Wow6432Node\&& set OSARCH=64) else (set OSARCH=32)
HTH,Bob
