V8i VBA view attributes fill on/off or V8I Key-in
I know about Ctrl B and click them on or off, but since the following work in VBA '[1] new ActiveDesignFile.Views(1).DisplaysDataEntryRegions = False ActiveDesignFile.Views(1).DisplaysLineWeights = True ActiveDesignFile.Views(1).Redraw What would I put for the fill to be on or off? I did search through the key-in set fill and set view, but could not figure out how to do it I have a vba routine that sets most of my needs for each new drawing, but found this fill was my problem on more that one drawing, so I was going to attempt to remove the problem and turn it on?
Parents Reply
  • Hi,
    I concluded from your question that you wanted a keyin that works in the key-in dialog in Microstation.
    (That is:  MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill True)
    You can even wrap this into VBA like CadInputQueue.SendKeyin "MDL KEYIN BENTLEY.VIEWATTRIBUTESDIALOG,VAD VIEWATTRIBUTESDIALOG SETATTRIBUTE 0 Fill True")
    But indeed, the API Function Jon mentioned is better coding style and works fine for me too. I even doubt that it is a problem of the Microstation version you use. So you should try again and implement Jons sample and tell us if it works for you .
    Regards, Stefan.
