could any one can help me with below error in VBA?
code:
Sub ShowTransientElementsold() Dim tec1 As TransientElementContainer Dim ele1 As Element Dim flags As MsdTransientFlags Dim eleEnum As ElementEnumerator Set eleEnum = ActiveModelReference.GraphicalElementCache.Scan Set tec1 = CreateTransientElementContainer1(Nothing, flags, msdView1 + msdView4, msdDrawingModeHilite) Do While eleEnum.MoveNext Set ele1 = eleEnum.Current tec1.AppendCopyOfElement ele1 Loop End Sub
error image :
i'm using V8i select series 2
regards,
vinoth
I don't know what's going on. I copied your code into a MicroStation V8i SS3 VBA project. It compiled without error.
Have you written other VBA code for MicroStation? Do your other projects compile and run without error?
i missed to attach few of the screen shorts to describe clearly.
TransientElementContainer not displaying in object browser:
references addequipmentattribute image:
and "TransientElementContainert" is missing in declaration list:
Vinoth
Vinoth Joseph
ATKINS
Bangalore, India
I think you are not working in Select Series. In your references, 'Bentley Microstation DGN 8.0 Object Library' is for V8.05*
For select series, it should 8.9 Object Library.
Sivag
TranslientElementContainer class was introduced in MicroStation 08.09.02
You may want to implement VBA class as follows:
Unknown said:TransientElementContainer not displaying in object browser
Here's what you should be seeing — the Bentley MicroStation DGN 8.9 Object library.
I don't know what Bentley vbprct0 type library is, but it is not VBA.
As others have indicated, you're using the V8.5 version of VBA with MicroStation SS2. At some point someone must have installed the earlier version of MicroStation after SS2. The solution is to reinstall SS2, which will add the necessary data to the Windows Registry.
Thanks Jon.
In "About microstation" dialogue box, it is indicating select series 2 version 08.11.07.443.
as you suggested, let me reinstall, then i will update you.
Unknown said:In "About microstation" dialogue box, it is indicating select series 2 version 08.11.07.443
If MicroStation V8.5 was installed or re-installed, for whatever reason, after MicroStation V8i then the VBA libraries, which are Windows COM DLLs, will be recorded in the Windows Registry. It's the MicroStation GUID that is important: the GUID is the same for all editions, so it's the most recent installation that gets Windows' attention.
MicroStation is a Windows application, so when it asks Windows for the VBA DLLs that correspond to its GUID then it gets whatever Windows thinks is the current DLL.
