could any one can help me with below error in VBA?
code:
Sub ShowTransientElementsold() Dim tec1 As TransientElementContainer Dim ele1 As Element Dim flags As MsdTransientFlags Dim eleEnum As ElementEnumerator Set eleEnum = ActiveModelReference.GraphicalElementCache.Scan Set tec1 = CreateTransientElementContainer1(Nothing, flags, msdView1 + msdView4, msdDrawingModeHilite) Do While eleEnum.MoveNext Set ele1 = eleEnum.Current tec1.AppendCopyOfElement ele1 Loop End Sub
error image :
i'm using V8i select series 2
regards,
vinoth
Thanks Jon.
In "About microstation" dialogue box, it is indicating select series 2 version 08.11.07.443.
as you suggested, let me reinstall, then i will update you.
Vinoth Joseph
ATKINS
Bangalore, India
Unknown said:In "About microstation" dialogue box, it is indicating select series 2 version 08.11.07.443
If MicroStation V8.5 was installed or re-installed, for whatever reason, after MicroStation V8i then the VBA libraries, which are Windows COM DLLs, will be recorded in the Windows Registry. It's the MicroStation GUID that is important: the GUID is the same for all editions, so it's the most recent installation that gets Windows' attention.
MicroStation is a Windows application, so when it asks Windows for the VBA DLLs that correspond to its GUID then it gets whatever Windows thinks is the current DLL.
