Cell preview through userform
is there any possibility to select and preview a cell through userform, wth VBA.
  • Unknown said:
    Is there any possibility to select and preview a cell through UserForm
    You can capture an image in several ways...
    1. Printing to an image file
    2. Screen Capture
    3. Using the Element.GetPicture method
    They are mentioned, with some sample VBA code, in this article Capture a MicroStation View Using VBA.
    In your case, read the cell from a library, then capture its image...
    Dim oCell As CellElement
    Set oCell = CreateCellElement2 ("Vinoth", origin, Point3dOne, True, Matrix3dIdentiy)
    Dim size_x As Long
    Dim size_y As Long
    ' Get size_x, size_y from an Image control
    Set object.Picture = oCell.GetPicture (size_x, size_y)
    Regards, Jon Summers
    LA Solutions
Reply
    2. Screen Capture
    Dim size_x As Long
    Dim size_y As Long
    LA Solutions
