Hello,For maintenance convenience, for reutilisability (of utilities and math modules / classes for example), and to avoid a too large project (.MVBA) file, I would like to split a quite large .MVBA project file (currently about 3 Mb) into many smallers MVBA projects.These smaller MVBA projects would be loaded in the same time by Microstation in the VBA IDE and would be able to exchange public Sub / Function / Form / Class / Variables between them.Unfortunately, I didn't found how to make this exchange working in the VBA IDE or in Microstation.Example : two projects are loaded in the IDE
Project_A.mvbaModule_A_01Public Sub f1()Project_B.mvbaModule_B_02Public Sub f2()When I call f1 from inside f2, I get an error (not found).Please, do you know the way to do what I expect ?Many thanks in advance for any advice.Bernard Chevalier (France)
You must add a VBA reference to each project that is used in another project. In your example, Project B references method f1 in Project A: you should reference Project A from Project B.
In the VBA IDE, use menu Tools|References to pop the References dialog. You will see your VBA projects in the list. Check the project(s) that you want to reference.
Answer Verified By: Bernard Chevalier
Thank you very much Mr Jon Summers for your answer.
I learned a lot about Microstation VBA reading your great website : http://www.la-solutions.co.uk/
As an alternate, you can send a key-in to Microstation to "vba run f2".
--Robert
Super help, solved a problem for me on sharing a Variable sFclose between projects. So appreciate all you smarter folks who take the time to help others. Was a big Help ! ! ! !
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
