VBA textbox and find/replace text syntax
I created a program that will create a new file (copy from a seed and place the newly named model in user location) followed by replacing various portions of text throughout a mutli modeled dgn file.
Unfortunately the 'replace' option of the program is hard coded.  I would like to allow the user to enter text into a textbox, press a commandbutton and that entered text will populate the CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING (entered data)" in a portion of code  CadInputQueue.SendCommand "MDL silentload KEYIN FINDREPLACETEXT,CHNGTXT CHANGE DIALOGTEXT" and replace the text in the models.  Does that make sense?
I have tried a couple other variations of revising/replace text and the find/replace gives me the preferable outcome, and so far it has been the easiest to follow.
I tried something like this(and a couple other variations), without any success:
CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING " & ReplaceBox1.Text, True
I am not the most proficient at VBA yet, as I am re-learning as I go, but with some success as I have taken classes about 10 years ago( 02 & 03) and are using the same old class books.   I get the 'Compile error: Wrong number of arguments or invalid property assignment' message box and the SendKeyin is highlighted, but not in yellow like during debugging.
Any help on the correct variable syntax would be appreciated or even a 'hey you are barking up the wrong tree with the find/replace tool, use (this) instead."
Thanks for any comments
The problematic portion of the code is here:
                If myModel.Type = msdModelTypeNormal Then
                ' verify that it is a cell
                    If myModel.CanBePlacedAsCell Then
                    ' make the model active
                    myModel.Activate
                    CadInputQueue.SendKeyin "FIND DIALOG SEARCHINCELLS True"
                    CadInputQueue.SendKeyin "FIND DIALOG ZOOM False"
                    CadInputQueue.SendKeyin "FIND DIALOG PAN False"
                    CadInputQueue.SendKeyin "FIND DIALOG SEARCHSTRING Full_Name"
                    CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING (entered data)"   'need to add value from textbox
                   ' CadInputQueue.SendKeyin "CHANGE TEXT FIND"
                    CadInputQueue.SendKeyin "CHANGE TEXT ALLFILTERED"
                    Counter = Counter + 1
                    End If
                End If
    You need to verify that your proposed command or key-in is valid.  If I key-in
    then I get a MicroStation error MDL loader: could not load application KEYIN.
    Since there isn't a KEYIN application, that's seems a reasonable message. It's nothing to do with VBA.  Try
    MDL silentload FINDREPLACETEXT,CHNGTXT CHANGE DIALOGTEXT
    Apart from that, your key-ins look good to me.
    Regards, Jon Summers
    LA Solutions
  • You are correct, the 'keyin' can be deleted and it still functions.  Thanks, anytime I can clean up the code I am happy.
    To help clarify further, if I change this line: CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING " & ReplaceBox1.Text, True
    to this:
    CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING wicked"   'need to add value
    The vba works great.  in every model the words Full_Name are replaced with wicked.  I would like to be able to have the user add their own text in ReplaceBox1 (VB textbox), click the commandbutton and process the text replacements, without the hard-coded  (entered data) is it does now.
    BTW - thank you for such a quick response.
    Move Code into Sub
    First, create a new procedure that contains your existing code...
    Public Sub ChangeText (ByVal find As String, ByVal replace As String)
      ... copy your above code here
    End Sub
    Change the following lines...
    to
    CadInputQueue.SendKeyin "FIND DIALOG SEARCHSTRING " & find
    to
    CadInputQueue.SendKeyin "FIND DIALOG REPLACESTRING "  & replace
    Create UserForm
    Add a UserForm to your VBA project.  Add two text boxes, one for find (name txtFind) and one for replace (name txtReplace).  Add a command button (name cmdChangeText).
    Click the command button.  VBA creates an event handler for you: cmdChangeText_click.  Add code to that procedure...
    Sub cmdChangeText ()
       ChangeText txtFind.Text, txtReplace.Text
    End Sub
    Test & debug.
    LA Solutions
    Answer Verified By: Jeremy Cswercko
  • Fantastic!   Worked like a champ.  Took the variable, dropped it back into my code, works great.
    Thank you for your help!
