mdlView_setFunction(VIEW_DRAWCURSOR,...) alternative in V8i
I migrate an application (native code) from V8 2004 to V8i. In the application I have a function synchronising the cursor position in a master view with a slave view. This is done using mdlView_setFunction(VIEW_DRAWCURSOR,...). When the function is set, each times the mouse is moved in the master, the function received the position and we draw a cross representing the mouse position in the slave view.
Since VIEW_DRAWCURSOR is deprecated, how can I do the same thing in V8i. I have take a look to the sample called Viewdeco but I cant found my happyness in this code...
Many thanks in advance.
Philippe HALET
  • Hi,
    You may try your luck with
    mdlView_setFunction ( VIEW_MOTION,   watchCursorInView );
    where:
    Private void watchCursorInView
    MSWindow   *windowP,       /* window in which motion occurred */
    int         xCoord,        /* current x screen coordinate of cursor */
    int         yCoord         /* current y screen coordinate of cursor */
    Also you can poll cursor with
          mdlSystem_getCursorPosition ( )
    HTH
    Cheers,
    /Chris Z.
    Answer Verified By: Philippe HALET
  • Hi Chris,
    I think this is a good way, but I cannot retrieve the "realworld" coordinates using mdlSystem_getCursorPosition(position, ..., dpUorsP).
    position is correct but in screen coordinates and dpUorsP comes with strange values...
    Do you have another idea to retrieve de coordinates of the mouse in world coordinates ?
    Philippe
    Philippe HALET
    CEO at beCAD a Gold Channel Partner
  • Hi Chris,
    It seems the function mdlSystem_getCursorPosition() has a strange behaviour. The coordinates returned in dpUorsP are wrong.
    I have found a workaround using "statedata.current.dpUors" to get directly the current world coordinates and this works perfectly for me.
    Do you think using directly "statedata" is a good thing ?
    Many thanks in advance...
    Philippe HALET
    In the long term, no: any public global variable is likely to disappear in a future version of MicroStation.
    If that works for you in the current version of MicroStation, then go ahead.  Put a comment in your code noting the likely demise (fr. disparition) of public global variables.
    Regards, Jon Summers
    LA Solutions
  • > It seems the function mdlSystem_getCursorPosition() has a strange behaviour. The coordinates returned in dpUorsP are wrong.
    Well, I haven't played with this particular function recently, but looking at the sheer amount of workarounds I have for the cursor coordinates in some places I found following alternate hints:
    1. Get raw cursor coordinates from Windows Win32 API: GetCursorPos()
    2. Obtain the MicroStation position via mdlWindow_globalOffsetGet().
    3. Shift the raw coordinates accordingly in order to land within MicroStation's global coordinates space.
    4. Use mdlWindow_pointTo...() as necessary
    5. Finally use mdlView_screenToPoint () to get into UORs
    I think this might be a definition of pain  ;)
    Cheers,
    /Chris Z.
