Adjust Building Edges to 90 Degrees using MDL's
Hi Guys,
Please find the attached image.
Requirement:Need to adjust building edges to 90 Degrees, based on the specified angle.
For Example building contains10 vertices, first i am finding angle between vertex 0,1 & 2 next 1,2 & 3 and so on ......
For Example user specified angle is 2 degrees, need to adjust the edge(if the angle lies between 88 and 92 Degrees) to 90 Degrees.
Here is the code
mdlLinear_extract(DpVer,&NumVert,&MsEleDsc->el,MASTERFILE);
 for(i=0;i<NumVert;i++)
                    if(i+2 < NumVert)
                        mdlVec_computeNormal(&dVec1,&DpVer[i],&DpVer[i+1]) ;
                        mdlVec_computeNormal(&dVec2,&DpVer[i+1],&DpVer[i+2]);
                        mdlVec_normalize(&dVec1);
                        mdlVec_normalize(&dVec2);
                        Angle = mdlVec_angleBetweenVectorsXY(&dVec1,&dVec2);
                        Angle = (3.14159265 - Angle) / 0.0174532925199433 ;
                        if(((Angle> (90 - <User specified angle>)) && (Angle< (90 + <User specified angle>))))
Successfully finding the angle between the 3 vertices.
Questions:
How to adjust the edge to 90 degrees (if the angle lies between user specified Angle) ?
2nd Vertex must be modified to set the angle to 90 Degrees but how ?
I am not asking for code ;-) , suggest me how can i adjust the edge to 90 Degrees.
    • Get the normal of the plane formed by the two vectors (hint: cross-product)
    • Rotate vec1 by 90° about that normal
    Unknown said:
    Need to adjust building edges to 90°
    I appreciate that you're involved in data cleanup, but it would be preferable if the CAD users were to take advantage of MicroStation's tools.  Built-in capability such as the AccuDraw compass enables the construction of accurate drawings.  Using those tools would make cleanup tools redundant.
    Regards, Jon Summers
    LA Solutions
    Answer Verified By: Daniel Christopher
  • Hi Jon,
    • Normal of the plane "mdlVec_normalizedCrossProduct(&Planenormal,&dVec1,&dVec2);"
    • Rotate vec1 by 90° about that normal ( vec1 == dVec1 ?)
    • How to rotate vec1 by 90 Degrees using "Planenormal" ?
  • 1.) use mdlVec_subtractDPoint3dDPoint3d to get vectors
    2.) calculate angle between those vectors and their crossproduct (check normal's directon)
    3.) create a transform matrix using mdlTMatrix_fromRotationAroundPointAndVector
    4.) use matrix to rotate points using mdlTMatrix_transformPointArray
  • Hi Dan,
    1)  mdlVec_subtractDPoint3dDPoint3d(&dVec1,&DpVer[i+1],&DpVer[i]);
          mdlVec_subtractDPoint3dDPoint3d(&dVec2,&DpVer[i+1],&DpVer[i+2]);
    2)   Angle = mdlVec_angleBetweenVectorsXY(&dVec1,&dVec2);
          mdlVec_normalizedCrossProduct(&pCrossProduct,&dVec1,&dVec2);
    3)  mdlTMatrix_fromRotationAroundPointAndVector(&transformP,&DpVer[i],&pCrossProduct,1.570796327);
    4)  mdlTMatrix_transformPointArray(pointArrayP,&transformP,3);
    Output:
    mdb> pointArrayP
    [0].x = 7719526.9854165446
    [0].y = 8296675.8804530893
    [0].z = 89445.407045140397
    [1].x = 7719261.6575013353
    [1].y = 8296629.4354537418
    [1].z = 89441.641368713914
    [2].x = 252610.33324784692
    [2].y = 6846384.9664532244
    [2].z = -131219.73550886242
    mdb> DpVer[i+1]
    .x = 387736.15717124939
    .y = 7379314.0008487701
    .z = 580.74257106782363
    mdb> DpVer[i]
    .x = 387738.46639060974
    .y = 7379316.0770320892
    .z = 580.77082663637952
    mdb> DpVer[i+2]
    .x = 387734.4656085968
    .y = 7379315.8822689056
    .z = 580.70930082661414
    mdb> dVec1
    .x = -0.74360178868447713
    .y = -0.66856083758040796
    .z = -0.0090986987547425034
    mdb> dVec2
    .x = 0.66853223922168625
    .y = -0.7435669108542966
    .z = 0.013148924056227015
    mdb> transformP
    .form3d[0][0] = 0.00024199973070624249
    .form3d[0][1] = -0.99992964356085534
    .form3d[0][2] = -0.011859568474073356
    .form3d[0][3] = 7766448.4161071312
    .form3d[1][0] = 0.99981468868857593
    .form3d[1][1] = 1.3651268208498285e-005
    .form3d[1][2] = 0.019250664825116434
    .form3d[1][3] = 6991537.5457176892
    .form3d[2][0] = -0.019249148518738095
    .form3d[2][1] = -0.011862029417590094
    .form3d[2][2] = 0.99974434859087868
    .form3d[2][3] = 94997.448188310969
    Is there any mistake ?
  • Unknown said:
    Is there any mistake?
    Who knows?
    Do you expect someone to analyse those numbers for you?  Why not draw the result to see what the calculation has produced?   Convert your pointArrayP to a line-string element to check visually.
    LA Solutions
  • Jon,
    Wrong output may i know where i am doing mistake ?
    I mean functions i am using are correct or not ?
  • Unknown said:
    I mean functions I am using are correct or not ?
    You really need to learn more about computational geometry.  Some books about that topic are mentioned here.
    LA Solutions
    I have suggested you correct functions, and you used them correctly, but with wrong data :).
    To get correct vectors for calculation of angle you must not just subtract 'some' points. You must subtract specific points in correct order.
    Vec[n0] = Point[n - 1] - Point[n];
    Vec[n1] = Point[n + 1] - Point[n];
    where Point[n] is a pivot point for rotation.
    In other words, you need to get two vectors of rays with common start point.
    As suggested Jon, first you must understand vector algebra.
    Without it, this discussion is loosing of time - yours and ours.
Reply
