Dear all,
I wanted to know if there is any way to check if there is an connection occurs with two cellElements. as shown in the figure,Only Point A coincides with Point B is considered as a connection .What would be the best way to achieve this?
Thanks in advance.
In addition to Jan's suggestion, you could include a point (i.e. a zero-length line) in the cell coincident with the connection point A or B. Put the point on a named level (e.g. connection points) to make it easy to find.
As far as I understood, DongLee wants to determine if cells have a common point - perhaps origin of the cell.Then simple comparison of origins should be enough, or comparision of points A and B in some tolerance. But only if I understood: "Only Point A coincides with Point B is considered as a connection ." correctly :)
