http://translate.google.it/
I have a macro that reads xls files (A2: A15) and creates layers in dgn. macro works, I see the layers created. I close and reopen Microstatio and levels have disappeared. any idea I enclose , dgn file , xls , macro, movie
to run the macro change inside the file path xls
In microstation vba help: AddNewLevel:
Remarks
This method returns the newly-created Level object.
Subsequently, you should call Levels.Rewrite to make the change permanent.
Laurent
Laurentd is correct, you will need to call Levels.Rewrite. Try updating your code as follows:
For i = 2 To 15 ' righe da file xls livello.levelname = foglio.Cells(i, 1) livello.levelcode = foglio.Cells(i, 2) If False = LevelExists(livello.levelname, True) Then Application.ActiveDesignFile.AddNewLevel (livello.levelname) Set oLevel = ActiveDesignFile.Levels(livello.levelname) Debug.Print "Level Name Added: " & oLevel.Name End If Next ActiveDesignFile.Levels.Rewrite
Function LevelExists(sLevelName As String, Optional bExactName As Boolean) As Boolean
Dim oLevel As MicroStationDGN.Level Dim oLevels As MicroStationDGN.Levels Dim bLevelInDGNLibrary As Boolean Dim sName As String sName = sLevelName ' Validate input If sName = "" Then Exit Function End If
' Perform "like" search for name If bExactName <> True Then sName = "*" + sLevelName + "*" End If ' Locate name Set oLevels = ActiveDesignFile.Levels Set oLevel = oLevels.Find(sName) If oLevel Is Nothing Then Debug.Print "Level name not found: " & sName Exit Function Else bLevelInDGNLibrary = oLevel.IsFromLevelLibrary Debug.Print "Level Name: " & oLevel.Name & ", Number: " & oLevel.Number & ", ID: " & oLevel.ID & ", InDGNLib: " & CStr(bLevelInDGNLibrary) End If LevelExists = TrueEnd Function
Answer Verified By: Massimo Callegher
it works perfect
thank you very much
