I’m developing a little module for drawing elements from a data file. My problem is that Microstation doesn’t create Dimension Elements as I expect.
My Dimension Elements are very simple. They must give the measure between two points and match a custom style given by its name. This is the code I use:
' Imports a DimensionElement.
Function GetDimensionElement(segment() As Point3d, StyleName As String) As Element
Dim oDimElem As DimensionElement
Dim oDimStyle As DimensionStyle
Dim i As Integer
Set oDimElem = CreateDimensionElement1(Nothing, Matrix3dIdentity, msdDimTypeCustomLinear)
Set oDimStyle = ActiveDesignFile.DimensionStyles(StyleName)
If IsNothing(oDimStyle) Then
Set oDimStyle = ActiveDesignFile.DimensionStyles(1)
End If
For i = 0 To UBound(segment)
oDimElem.AddReferencePoint ActiveModelReference, segment(i)
Next i
Set GetDimensionElement = oDimElem
End Function
When I must get a dimension like this:
I have something like this:
It seems that Dimension Style has design or view alignment, but it doesn’t. It’s true alignment.
I’ve tried too modifying some properties after and before creation, without success.
Any suggestion will be appreciated.
Javier Rufas
I found you created an oDimElem and an oDimStyle but I can't find the code you set oDimStyle to oDimElem. So I think you miss a below line:
oDimElem.DimensionStyle = oDimStyle
HTH, YongAn
I forget a little detail. I've lost a:
Set oDimelem.DimensionStyle = oDimStyle
But that doesn't work.
And changing Type doesn't too. This is the last code:
'' Imports a DimensionElement.'Function GetDimensionElement(segment() As Point3d, StyleName As String) As Element Dim oDimElem As DimensionElement Dim oDimStyle As DimensionStyle Dim i As Integer
Set oDimStyle = ActiveDesignFile.DimensionStyles(StyleName) ' If StyleName doesn't exist, get Active Style If IsNothing(oDimStyle) Then Set oDimStyle = ActiveSettings.DimensionStyle Else ' Set Active Style to StyleName Set ActiveSettings.DimensionStyle = oDimStyle End If ' Create Dimension element with ... Active Dimension Style? Set oDimElem = CreateDimensionElement1(Nothing, Matrix3dIdentity, msdDimTypeUseActive) 'Force Dimension Style 'Set oDimElem.DimensionStyle = oDimStyle For i = LBound(segment) To UBound(segment) oDimElem.AddReferencePoint ActiveModelReference, segment(i) Next i Set GetDimensionElement = oDimElemEnd Function
Hi Yongan.Fu,
Thank you for your answer, but that doesn't work too.
Now, I supect that I must give to CreateDimensionElement1 the correct RotationMatrix.
I interpreted that it's an additional element trasnformation, but I'll build a RotationMatrix from segment ... and I'll see.
SOLVED.
It was the rotation matrix (I don't know that happens if It creates a dimension element for a Linestring with more of two points).
Te Final code is:
'' Imports a DimensionElement.'Function GetDimensionElement(segment() As Point3d, StyleName As String) As Element Dim oDimElem As DimensionElement Dim oDimStyle As DimensionStyle Dim RotationMatrix As Matrix3d Dim i As Integer
Set oDimStyle = ActiveDesignFile.DimensionStyles(StyleName) ' If StyleName doesn't exist, get Active Style If IsNothing(oDimStyle) Then Set oDimStyle = ActiveSettings.DimensionStyle Else ' Set Active Style to StyleName Set ActiveSettings.DimensionStyle = oDimStyle End If RotationMatrix = Matrix3dFromAxisAndRotationAngle(2, GetActiveAngleFrom2Points(segment(0), segment(1)))
' Create Dimension element with ... Active Dimension Style? Set oDimElem = CreateDimensionElement1(Nothing, RotationMatrix, msdDimTypeUseActive) 'Force Dimension Style 'Set oDimElem.DimensionStyle = oDimStyle For i = LBound(segment) To UBound(segment) oDimElem.AddReferencePoint ActiveModelReference, segment(i) Next i Set GetDimensionElement = oDimElemEnd Function
'Modified from VBA Help
Function GetActiveAngleFrom2Points(pt1 As Point3d, pt2 As Point3d) As Double Dim vec1 As Vector3d, vec2 As Vector3d Dim angle As Double 'get vectors in plane of view vec1 = Vector3dSubtractPoint3dPoint3d(pt2, pt1) vec2 = Vector3dFromXY(1#, 0#) 'duplicate keyin logic angle = Vector3dAngleBetweenVectorsXY(vec2, vec1) GetActiveAngleFrom2Points = angleEnd Function
Answer Verified By: Javier Rufas
