I’m trying to redefine a line in an existing custom vb programme and I have only just started to understand vb.net but have written in vba previously (some years ago).
This is the line I want to edit:
StartProjectNumber = MSApp.ActiveWorkspace.ExpandConfigurationVariable("$(first(_USTN_PROJECTNAME))")
The history… I’m trying to tidy up a messy workspace and part of that is the project list, we have four and five digit project numbers but due to the numeric nature of the list our 10000 numbers appear at the head of the list when they should follow behind 9999. This is easy enough to fix which I did by adding a preceding ‘0’ to the four digit numbers to make them all five digits but I didn’t anticipate the effect on some custom programming, which verifies the correct project is open against the open file.
The result is the programme now fails because it interprets 09999 from the pcf as not matching the directory which is actually 9999.
So I need to find a way of either redefining "StartProjectNumber" so that the expanded variable $(_USTN_PROJECTNAME) loses the preceding zero or look at replacing it with a shortened path from $(_DGNDIR) i.e. $(_DGNDIR)=S:\9999\ to drop the ‘S:\’ and end ‘\’ to get ‘9999’
Any suggestions will be gratefully received.
Thanks.
Have you considered using Microsoft's VB.NET String.Replace method, or some of Microsoft's other VB.NET String Methods? Microsoft also provides an introductory help topic that may be of help titled: "Strings in Visual Basic"
HTH,Bob
Unknown said: I need to find a way of either redefining "StartProjectNumber" so that the expanded variable $(_USTN_PROJECTNAME) loses the preceding zero or look at replacing it with a shortened path from $(_DGNDIR) i.e. $(_DGNDIR)=S:\9999\ to drop the ‘S:\’ and end ‘\’ to get ‘9999’
One way to handle complex string searches and substitutions is to use Regular Expressions.
Thanks for the pointer Bob but I'm not convinced I can use this method as the variable _USTN_PROJECTNAME by its nature could be anyhing. I need to interrogate the result verify if it has a preceding '0' and if it has redefine to remove it for the purpose of the programme, I'm making some assumptions here that it will not redefine for the rest of the MicroStation session though?
I may be better off using the _DGNDIR variable instead if I can remove the drive details?
Thanks Jon, I'll do some reading and see if I can utilise these.
Unknown said:Any suggestions will be gratefully received
I used LINQPad to write some code to analyse your path using VB.NET methods and Regular Expressions...
Here's the code...
Debug.WriteLine("Parsing folder path using VB.NET methods") Dim path as Stringpath="S:\9999\"Debug.WriteLine ("Path=" & path)Dim drive as String = Microsoft.VisualBasic.left(path,3)Debug.WriteLine ("Drive=" & drive)Dim last As String=Microsoft.VisualBasic.Right(path,1)Debug.WriteLine ("Last=" & Last)Dim folder As String=Microsoft.VisualBasic.Mid(path, 4, Microsoft.VisualBasic.Len(path)-4)Debug.WriteLine ("Folder=" & folder)Debug.WriteLine ("Parsing folder path using Regular Expressions")Dim regex As System.Text.RegularExpressions.Regex = _ New System.Text.RegularExpressions.Regex("\d+")Dim match As System.Text.RegularExpressions.Match = regex.Match(path)If match.Success Then Debug.WriteLine("Folder=" & match.Value)End If
Really appreciate the example Jon, on interrogating the existing code I identified an example of a Mstn variable being stripped down, in this instance it was MS_DEF, so I took a punt and tried the exact same settings for _DGNDIR here it is:
StartProjectNumber = Replace(Mid(MakeFile.CleanPathText(MSApp.ActiveWorkspace.ExpandConfigurationVariable("$(first_DGNDIR))")), 4, 5), "\", "")
I'm not entirely sure how it is working other than using the "\" to identify but it appears to be generating just the project number part of the file path and because the directories have not been changed to add a preceding '0' the rest of the programme works correctly.
In my example:
_DGNDIR = S:\2393\PlanChest\0200-(GA's-Full)\
and after the definition is made:
StartProjectNumber = 2393
If you can explain how the capture is working from the example above it would make it easier to utilise these settings in future code?
Your example is very helpful though, I have just jumped straight into VB and didn't even know how to generate a debug.
Cheers
Answer Verified By: CAD-wiz
debug your code by setting a red marker at the very beginning of a line. if the line is hit by the code the debug window will pop up.
Your example works because of the MID- Function. See : msdn.microsoft.com/.../05e63829(v=vs.90).aspx
Regards, Stefan.
Yep I'm used to the debug in Mstn VBA interface but Visual Studio is somewhat different, thanks for the link.
Ok, I misunderstood it. If you are writing managed code in vb.net I would suggest using Visual Studio. Debugging is almost the same as in VBA but you have to connect to the application.
