[V8 MDL] Is mdlElmdscr_areTwoIdentical broken?
I wrote some VBA code to compare two elements.  The VBA code calls into the MDL.  The VBA code uses mdlElmdscr_areIdenticalToTolerance because mdlElmdscr_areTwoIdentical never returns True.
