I'm trying to upload a document to a PW project from a asp.net web application. I was able to use the API to login. I'm now trying to use the aaApi_CallDefaultWizard to bring up the wizard to upload a file.
I have declared the function like this:
[DllImport("dmscli.dll", CharSet = CharSet.Unicode)] public static extern string aaApi_CallDefaultWizard(IntPtr hWndParent, string lpctstrTitle, int ulCategoryId, int lMessageId, int ulParam1, int ulParam2, IntPtr lplResult);
I'm not sure how to actually call this. The closest I've seen to an example is this C++ code, but I'm not able to do this in C#. Not sure how the paramaters are created. http://communities.bentley.com/products/projectwise/projectwise_programming/f/342995/t/92484.aspx
Is anyone able to point me in the right direction or a C# example please?
were you able to do it? I want to do the same thing.
