Hi All,
I'd like to know if there is a way (and what is the way if such is the case) to do an update server copy programmatically from Autocad.
Thanks.
Ludovic, there is not a way to interact with the desktop integration other than to use the autocad commands defined by the desktop integration dll. Those are referenced here: communities.bentley.com/.../5525 It would be nice if they added that command.
