Respected sir: Thank you first to read my post. I learn NRF24L01 not long ago. Recently I bought a NRF24L01PT from an electronic site and began to research it. I met questions while I have been confusing it a long time when I’m adjusting program. I send the program according to the adjusting way--disability response,disabled automatic re-transmission and receive channel 0 in the disability which referring to the datasheet of NRF24L01PT . If it can send successfully the STATUS should be "0*2e (46)", there are not problem. However! ! The another fifo_status should be "0*11",but here just be "0*01", what mean that TX_FIFO is no empty...so I add "spi_rw_reg(flush_tx,0)" which set before delivery mode when I sent the program.II have try it even add it in the main function, , , , , , Unfortunately,It’s always "0*01".I have no choice. Can any manipulators here help me. If you could give me some feasible suggestions,I'll be appreciated! Best wishes~
Dear sir, I happened to see your post, I found NRF24L01PT on a website, maybe you can turn to some electronic components online shop for help because they have professional engineers, such as Jotrin Electronics Limited or mouser, Digikey.
ok, thank you very much
i like your article
Freewing rc airplane
I hope that https://www.heisener.com/ will help you solve your problems and find the answers you are looking for.
Being a trusted online electronic parts/components supplier, Heisener partners with original manufacturers. Enjoy affordable prices for quality products.
Thank you for your article, take a look at this Nantian Electronics, hope it can help youDF02S-T,This electronic component can replace yours
I hope https://www.pneda.com/ can help you find a solution to your problem.
