On the server side (ProjectWise Integration Server). In C:\Program Files\Bentley\ProjectWise\Bin\dmskrnl.cfg there is a section for plugins or server customizations. It looks like this:
[UserModules] ; ----------------------------------------------------------- ; Section provides user customized modules ; ----------------------------------------------------------- ; On start up the server will read this section and load any listed DLLs. ; The dll is not unloaded until the server is shut down. ;dmsgeosrv=dmsgeosrv.dll ;EventLogging=EventLoggingATP.dll ;drmsvcsrv=drmsvcsrv.dll
Does anyone know how to write a server plugin or what can be done using a server plugin?
Hi Daniel,
I am also looking for the same thing. Where you able to find? If you find please tell us so that it will be much helpful. Thank you.
Ramnath.
I found no information on this topic. Good information for developers is not really Bentley's thing.
