C# change project environment
C#
Looks like I need to use AAPI_MODIFYPROJECT2 to apply changes to a Project , how do I get the Project object with C#?
I can select using AAAPI_SELECTPROJECT(id) ; but I don't know to 'access' the selected Project object  .
Thanks for your patience
Kevin.
  • There are no "objects" in the PW SDK in the same sense as you would have in C#.  aaApi_SelectProject() fills the static buffer AADMSBUFFER_PROJECT (as the SDK documentations states).
    You can access that buffer with functions like aaApi_GetProjectNumericProperty() or aaApi_GetProjectStringProperty(), but because working with folders, etc. is so common, you will find many purpose specific functions such as aaApi_GetProjectIdByNamePath(), etc.
    Answer Verified By: Kevin
