I'm new to PW Api, I was looking on the c++ samples (mymenu) in the SDK folder. Is there a way to add menu from C#? Online posts are too old, just checking if anything new came.
Yes, but it is up to you to handle calling native code from your managed code, or more precisely, you would have to setup your managed code to be callable from native code because that's what ProjectWise Explorer is running as.
You can Google how you might do this, for example https://www.codeproject.com/Articles/37675/Simple-Method-of-DLL-Export-without-C-CLI but there's more than one way of course.
