I'm writing a program which extract informations from PW datasource, using the Web Services Gateway.
We use Bentley IMS to connect to datasource, so I want to use the same method. The documentation mention Bentley STS and OAuth2, but is not very precise and I don't find a way to achieve that :
All requests having a {RepositoryId} parameter must have one of the following:
Does anyone can explain how to configure the header using the token, or give an example ?
Benjamin
Headed out on vacation, but I will delve into the Azure AD and ADFS problems when I return in a couple of weeks. Will share if I have any luck.
Dave
We have a significant project coming up that is looking for OAuth2 authentication agaisnt the PW WSG. Has there been any progress on this?
Sorry, Damian. This fell off my radar. I will get some of the guys to start looking at it. Dave.
Damian, did you consider using ProjectWise Flow connector (https://us.flow.microsoft.com/en-us/connectors/shared_bentley/projectwise-design-integration/) via either Microsoft Flow or Azure Logic Apps? This is probably not exactly answering this question but I hope it may help. Please let me know if you have further questions about capabilities and use of the connector.
Hi Audrius,
I have a use case (real) :
My issue is, since we only use IMS accounts, and we are federated, currently I don't know how to get a token directly from my script.
I have to use a powershell cmdlet from pwps_dab to get a token from the connection client, store it in a file, and then use it in my script.
In fact I would like to understand how to implement almost the same authentication method that you used for the Flow connector.
