i'm looking for some help from the Projectwise programming expertise to get some information or sample code to connect with projectwise by providing user ID and password and then extract list of files from a folder path.
I'm just new to C#. if anybody can share a sample code, it will be highly appreciable.
many Thanks,
You can download the PW SDK and once installed you will find help and sample code. The SDK is native code, so you will have to deal with calling unmanaged code from your managed code, but it is perfectly "doable".
Make sure that you download a version of the SDK that is for the version of ProjectWise that you are targeting. Most of your code will work with multiple versions of ProjectWise, but make sure that you review the "ProjectWise SDK Impact Statement" that comes with each release for what is new, changed, deprecated, removed or modified.
Good luck!
Thank You Dan.
I searched for PW SDK exe file on Google. Many times its pointing to Bentley communities, but not identified any working folder path to download.
(one of the example is http://appsnet.bentley.com/myselectcd/ with error 404)
I'm using PW V8i ss4 version 8.11.11.584.
could you please guide me from where I can download the needed installation file.
Vinoth Joseph
ATKINS
Bangalore, India
There isn't any "working folder path" to download the SDK, nor is there an PW SDK exe file. You can get the SDK from the Fulfillment Center .
Take a look at this post:
https://communities.bentley.com/products/programming/projectwise_programming/f/projectwise-programming---forum/147242/where-do-i-find-the-projectwise-sdk-we-are-registered-as-bentley-developers/447936#447936
IMHO, searching for a specific SDK isn't as easy as some would like, so here's a screenshot of how to find the PW SDK for the generation of product that you mentioned:
and a link: https://select.bentley.com/FulfillmentCenter/en/Search/Product/LTEyMzE5NjgyOTdfNC4wLjIuMA?namedfilter=showdefault&SubProductLineID=335&GenerationID=119&ReleaseTypeId=169&date=1992710147
Hi Dan, No luck yet. see the image below.
Vinoth
I do not get the results Dan gets either. When I chose ProjectWise and Bentley Developer Network, I get the ProjectWise Explorer in the list with three CONNECT Edition SDK downloads. If I add V8i to the filter, the ProjectWise Explorer option goes away.
