Hi.
We have made some development under WSG 02.00.03.63 up against a V8i (08.11.11.590) DataSource. Works like a charm.
Now we are upgrading to CONNECT (10.00.03.49) with WSG 02.06.07.07.
But for now we would like to test against our V8i DataSource.
Does WSG 02.06.07.07 work against a V8i DataSource. We do seem to have some problems.
Which version of the Plugin is the correct version to use. For now we have tried different things, and are currently using 10.00.03.49, but should perhaps use the Plugin 02.00.03.63, will this work with WSG 02.06.07.07.
Best regards Christian
