I want to change/edit Attributes for the files more 100 created in PW. Is there simplest way to do this as batch process using any macros?
Kind Regards,
Balaji
Use Export/Import feature. No programming required. Export template spreadsheet, make the changes, Import it back in.
Lyon,
Please can you explain/provide the steps to do this....I don't know really how to do it?
These instructions are in the Content Management Wiki. Please ask questions about it in the Content Management forum. This is the programming forum.right-click-document-folder-export-tools-export-import-wizard-export-import-with-excel-tn
