I am trying to use the WSG to execute document workflow commands (like Previous state, Next state or something customizable in the workflow definition)
I managed to retrieve possible commands for a specific document using the DocumentCommand relation.
Now the question is, how to run a command ?
I noticed another relation, DocumentCommandRun, which links a Document instance to a CommandRun instance.
The CommandRun class has the following properties:
CommandId Comment Messages ObjectId Status StatusMessage
I thought ObjectId would be the Guid of a Document and CommandId the id of the associated Command.
But when I tried to create a CommandRun, I keep getting the error, no metter what I put in the properties :
"Parent instance id must be specified for specified creation."
I am clueness. Could anyone tell me how to run a document command ?
Thank you
