Which aaapi function should be used in order to open a content window for flat document set?
Currently, I've figured out how to call dialog for simultaneous modification of multiple sets
aaApi_ModifySetContentDlg ( hwnd, NULL, mProjId, setSetId ); - it also can be observed after clicking context menu => set => modify...
Does anyone know some special call to open content window for particular flatset (it pops up after clicking context menu => set => content)?
I'm not in a position to actually check this, but searching the help with *aaapi*set*dlg*, and then clicking on "Document Set Dialog Functions", my guess would be aaApi_SelectSetDlg(), but it might be one of the others in the search results.
Thanks for your response. Unfortunately, it isn't the required window. I've tried calling aaApi_ModifySetContentDlg, aaApi_SelectSetDlg, aaApi_SelectSetMembersDlgExt, aaApi_CheckOutDocumentSetDlg so far. But still no signs of flat set content window like this:
That is not a dialog, that is a Document List Frame. I create one in the sample below to show the results of my search. I don't see a function that returns a DocumentListFrame in the Set API calls. For what its worth, this is how I posted documents to a frame. The code is in C/C++
void CreateAndDisplayDocumentSearch(LONG lProjectId) { //FILE *fp; //_TCHAR line[256]; //CStringArray caFolderList; WCHAR value[64] = L""; CString line; CString csSQueryName = _T(""); LONG lIndx = 0; LONG lSearchCount = 0; LONG lProjectCount = 0; HAADMSBUFFER hCriteriaBuf = (VOID *)NULL; HAADMSBUFFER hSavedSearches = (VOID *)NULL; //HDSOURCE m_hDataSource; const GUID pset_DOCUMENT_GENERIC = PSET_DOCUMENT_GENERIC; LONG lSQueryId = 0; //ID created AADSCTREEITEM dscItem; HWND hWndFrame = (HWND)NULL; HWND hWndList = (HWND)NULL; HTREEITEM hSearchTree = aaApi_DscTreeSelectSearchResultsItem (NULL, aaApi_GetActiveDatasource ()); //Creating Search Criteria Buffer Contents _ltow_s(lProjectId, value, 64, 10); hCriteriaBuf = aaApi_SQueryCriDataBufferAddCriterion(hCriteriaBuf,lIndx+1,VT_SINGLE_VALUE,&pset_DOCUMENT_GENERIC, _T(""), QRY_DOC_PROP_PROJ_ID, DMS_RELATION_EQUAL,AADMS_ATTRFORM_DATATYPE_BIGINT, value); if ( hCriteriaBuf == NULL ) { line.Format(_T("project criteria creation failed when trying to add project %d."),lProjectId); WriteErrorToLog(line); } _itow_s(1, value, 64, 10); //Setting Include Subfolders to 1 or TRUE //This is supposed to be like checking the include subfolders box hCriteriaBuf = aaApi_SQueryCriDataBufferAddCriterion(hCriteriaBuf, lIndx+1, VT_SINGLE_VALUE, &pset_DOCUMENT_GENERIC, NULL, QRY_DOC_PROP_INCSUBVAULTS, DMS_RELATION_EQUAL, AADMS_ATTRFORM_DATATYPE_INT,value); if ( hCriteriaBuf == NULL ) { line.Format(_T("project criteria creation failed when trying to add subfolders for project %d."),lProjectId); WriteErrorToLog(line); } memset (&dscItem, 0, sizeof (dscItem)); dscItem.ulMask = AADSCTIM_TYPEID | AADSCTIM_DATASOURCE | AADSCTIM_ITEMID; // some flags are skipped for simplicity dscItem.hDataSource = aaApi_GetActiveDatasource(); dscItem.lTypeId = DSCITYPE_SEARCH_RESULTS; dscItem.hItem = hSearchTree; hWndFrame = aaApi_CreateDocumentListFrame(aaApi_GetMainFrameWindow(), 0, 0, 512, 512, &dscItem, &hWndList); aaApi_FindDocumentsToDocumentList(hWndList,hCriteriaBuf); aaApi_DmsDataBufferFree(hCriteriaBuf); hCriteriaBuf = (VOID *)NULL; }
