I am working on getting the saved search result.
Through forum got to know I cannot get the result of the saved query, I have to use the aaApi_Find_item..or aaApi_FindDocument methods.
So I tried using aaApli_FindItem but cannot make it work for the criteria
I have 2 criteria
1. checkout document
2. checkout for more than a day.
Following is the code I am using
INT groupId = 123; criteria = aaApi_SQueryCriDataBufferAddCriterion (criteria, groupId, GT_RESTRICTION | VT_SINGLE_VALUE | UT_REGULAR, &psetDocumentGeneric, L"", QRY_DOC_PROP_DMSSTATUS, DMS_RELATION_EQUAL, AADMS_ATTRFORM_DATATYPE_STRING, L"Checked Out"); criteria = aaApi_SQueryCriDataBufferAddCriterion (criteria, groupId, GT_RESTRICTION | VT_SINGLE_VALUE | UT_REGULAR, &psetDocumentGeneric, L"", QRY_DOC_PROP_CHECKOUT_COUTTIME, DMS_RELATION_GREATERTHAN, AADMS_ATTRFORM_DATATYPE_DATE_TO_DAY, L"1");
With only first criteria , it works but the documents retried are more than 5000 , which is not true. If I give second criteria the FindItem method return False.
I have tried using FindDocument but could not figure out the parameters to pass
LPCRESULTCOLUMNS lpResultColumns=NULL;(how to define this columns) LPCFINDDOC_RESULT reactor; BOOL bResult = aaApi_FindDocuments(hBuffer(got from the aaApi_SQueryDataBufferSelectAll), lpResultColumns, FindDocumentCallback, &reactor,false,0,0);
Any help is appreciated. Thank you.
Rashmi.
